Fulltone: Deja Vibe 2
Started by z80808, October 03, 2019, 02:25:02 PM
z80808
I have a Fulltone Deja Vibe 2 which I believe is not phasing / swooshing as deep as it was when it was new: low effect level.  The pedal is 100% working, no clicks or pops, etc.  Note: The Chorus setting is much more noticeable than the Vibrato setting.  The Vibrato setting is too subtle.
What can I check, or change to restore the effect level?
GibsonGM
Welcome, Z!  Can you find and post a schematic to it?   That would give us some info to work from, to send you to check!
z80808
Unfortunately, I could not find a schematic of the model I have.  But, I did find one schematic that may be close enough:
Circuit: http://www.pisotones.com/Univibe/Stratotrasto/FOTO3.jpg
Basically it is a copy of a Univibe.  Note: The schematic is missing the vintage / modern switch.
Inside my pedal: https://fr.audiofanzine.com/tremolo-vibrato-guitare/fulltone/deja-vibe-2/medias/photos/#id:76801
Kevin Mitchell
#3
Check on the power supply. You should have upwards 17 or 18 volts going into the LFO circuit and about 15V for the signal. I wonder if the bulb isn't shining as bright due to lack of power. Otherwise I'd question the lamp-driver transistor which could be on it's way out.
If that checks out I would audio probe the signal to see if it's dying out somewhere in the phase stages.
But these are guesses.
-KM
z80808
Thanks for your response Kevin.  Will run the testing suggested and post my findings.
Z
