Small amplifier using KA2206 ?
Started by Electron Tornado, October 28, 2019, 09:24:02 PM
Electron Tornado
Has anyone tried the KA2206 for a small amplifier? A search here showed it was only mentioned in passing in a discussion 12 years ago.
Datasheet: http://pdf.datasheetcatalog.com/datasheet/SamsungElectronic/mXvvrus.pdf
"Corn meal, gun powder, ham hocks, and guitar strings"
Who is John Galt?
You will need about 0.8A (800mA) to push 5W in 8 Ohms BTL, so not your cheapest 9V adaptor.
Otherwise, amp is amp. Low-volt amps can't afford "soft overload", they just clip.
Electron Tornado
I was thinking more about just doing a 2.3 watt version into 4 ohms.
Who is John Galt?
bool
You will most likely end up with same-ish power requirements.
Looks like your chip is somewhat similar to the ubiquitous TEA2025.
