Grow Your Own Guitar Pedal Finish, Chapter 2
Started by EBK, December 13, 2019, 10:27:55 AM
I'll give future update pics their own post, I think.  I felt free to overwrite the last one because it was the same as t=0 days.
Anyway, it is definitely growing something.  Hard to tell what the crystals look like because they are only semi-opaque.
moid
I'm confused. When is the pedal going to take it's clothes off? This is pretty intense teasing.... :icon_lol:
On a more whimsical note, this is a really cool idea. When I was a child I was given a strange (and probably illegal for kids now) chemistry experiment called Crystal Garden which grew beautiful and rather fantastic worlds inside jam jars of water... something like this:
these were very fragile, but I wonder if they could be induced to grow between two sheets of clear perspex and then the plastic / crystal sandwich could be glued to the pedal top? For maximum complexity / awesomeness, cut a section out of the enclosure lid, out LEDS inside and place the crystal in its plastic sandwich in the hole and have it be backlit by the LEDs.
Mushrooms in Shampoo -  Amidst the Ox Eyes - our new album!
https://mushroomsinshampoo.bandcamp.com/album/amidst-the-ox-eyes
Apparently still K-12 legal in this 21st century:
https://engineering.oregonstate.edu/momentum/k12/june04/
Water, salt, ammonia (yum), and laundry bluing. Bluing has been out-of style in the US since chlorine, enzyme, and "brightener" products came to laundry mid-20th-century, but they still make it, and it is popular in simpler India to take the "yellow" out of washed cotton. In US look for a small bottle with grandma Stewart's picture. In UK they have Reckitt's Crown Blue Tablet. Bluing appears to be a trace of Prussian blue, what machinists use to mark steel, and apparently you can eat 10 grams a day OK. The crystals are salt, ammonia speeds evaporation, and the PB makes the crystals prettier. Food dye can be added for color.
Quick view from above at t=2 days:
That bubble is on the surface of the liquid, not on the enclosure.
And, from the usual angle:
(Just pretend that says "• LIVE FEED" in red letters if you still need that.  :icon_wink:)
I think what I will do next is, after I pull this enclosure out of its bath (maybe another day or two), I will resaturate the solution and hang some strips of aluminum flashing in it.  That way, I can do some experiments on sealing techniques without destroying a large quantity of my alum.  I want to at least try rattle can clear coat, CA glue, and epoxy.
Update: test strips are ready to go, or more accurately, ready to grow.
Looks like I need to rethink this a bit....
I moved it, and the crystals slid off like sheets of ice.
Interesting oxidation of the aluminum too.
Did you throw another box in the bath? I'm still seeing one in there on the live feed ;)
It will live there forever, I suppose.   :icon_wink:
I would need to filter out the crud from the Elmer's glue before trying again.  Will probably try some tests with the aluminum strips first to see if I can manage better adhesion.  Maybe CA glue and some of these new crystals as seeds.
