Square-Rooting a Signal?
Started by thehallofshields, January 24, 2020, 12:27:13 AM
thehallofshields
Looking at the Datasheet of the AD633 Multiplier, I came across this application:
When we multiply sine waves, we know that we get the sum and difference frequencies.
When we square a signal (multiply a signal with itself), we double it (octave). That math is easy to work out.
What happens when we 'divide' two signals?
How does the math work out when we squareroot a signal?
A google search turns up something like half-wave rectification, but is that accurate? If so, why?
DrAlx
thehallofshields
How different is that wave-form from half-wave rectification?
QuoteHow different is that wave-form from half-wave rectification?
There's one thing not made clear in that example.
sqrt(x) only makes sense for x >=0;  for x < 0 you get complex numbers.
When you do sqrt(sin(x)) it only makes sense for sin(x) >= 0.
So what missing is the part about throwing away the signal when it is less than 0.
ie. the thing that isn't mentioned is the fact there is half-wave rectifying going on
before you get to the sqrt(x) part in order to prevent complex numbers!
(the sqrt() *isn't* doing the half-wave rectification.)
So once you understand that mechanism the difference between sin(x) and sqrt(sin(x)) is the top of the sinewave becomes fatter like a soft clipped waveform.   Just notice sqrt(0.5) = 0.707 > 0.5   and sqrt(0.9) = 0.95 > 0.9 implying the top is flattened.
If you wanted to make a symmetrical sqrt() signal like you get with a clipped amplifier you would need to modify the sqrt() to be
a) Vout =   sqrt(Vin) for Vin >=0  and -sqrt(-Vin) for Vin < 0
There's many way to write this, which are all the same
b) Vout =   sqrt(Vin) for Vin >=0  and -sqrt(abs(Vin)) for Vin < 0
c) Vout  = sign(Vin) * sqrt(abs(Vin))
Where abs(x) = absolute value of x
sign(x) = the polarity (or sign) of x;   +1 for x > 0, -1 for x < 0, 0 or 1 for x=0 (whatever)
I forgot to mention a simple way to do a power of x in analog electronics is with exp() and log() functions
x ^ p  =  exp(ln(x^p))  = exp(p * ln(x))
So you have circuit which does ln(), multiply that signal by p, the put that through a circuit which does exp().
For square root you would use p = 1/2.
The ln() and exp() functions are implemented with transistors and diodes!   Look up logging circuits.
In principle they are straight forward but you can get practical problems with DC offsets.
Here's an old-style analog circuit that does square roots (from national semiconductor applications notes),
Steben
#5
So you can bias it on the positive side right to a couple of hundred mvolts in order to make it useful for guitar? Or higher bias after a gain stage
But can't a BJT stage with a very carefully designed feedback do the same?
QuoteSo you can bias it on the positive side right to a couple of hundred mvolts in order to make it useful for guitar? Or higher bias after a gain stage
Sure, there's plenty of ways of getting the general signal shape.   For a guitar they all end-up sounding different and there's no "correct" circuit.
The difference between those and square-root circuits (or any mathematical based circuits) is the the aim is to provide a mathematically correct square root and also to produce accurate square roots over a wide range of input levels.   For example you might build a true rms converter for a multimeter which needs both squaring and square-root circuits.   Here you want the calculations to be accurate.
See page 34 of,
https://www.americanradiohistory.com/Archive-Electronics-Today/ETI-Circuits-No-2-1978.pdf
Because this isn't such an easy task to do true-rms chips evolved.  Nowadays you might find a microprocessor with a A/D converter and the rms calculations done in software.
