Strange sound from my Rebote 3
Started by JCoobs, January 28, 2020, 09:05:09 AM
JCoobs
I'm getting a strange ticking/chirping sound in the background from my Rebote 3 I built. I've tried rearranging the order on my pedalboard. No difference. Any suggestions?
Does it chirp if you have it on its own?  Guitar->pedal->amp?
JCoobs
Yes whether it's on or in bypass. The Rate control makes it go faster or slower
mth5044
Are you using a tonepad PCB, make your own, perf, breadboard? What IC are you using in the LFO?
I meant when it's off your pedal board - so it's the only thing physically between your guitar and amp.
JCoobs
Yes I tested it by itself. Just guitar-pedal-amp.
I used the Tonepad pcb and I checked all the ICs. 2 TL072CP, 1 L7805CV3, and 3 PT2399.
3 2N5087 transistors
