Inductors and Gyrators (Acoustic 360 Project)
Started by Rob Strand, November 13, 2017, 09:57:05 PM
Quote300Hz 100mV p-p input (My input is ±100mV. Is it OK, or I need to inject ±50mV?), Q5 base shall be at 400mV and Q4 base at 1.2V. Q6 base shall be at 800mV.
If I read this CRO well, I have 1.2V at Q4, 400mV at Q5 (but bottom is flipped) and 600mV at Q6. So Q5 is definitely a suspect, just have no idea what's going on...
The way I read it is you would need +/- 50mV to match the 100mV p-p (peak to peak) in the service manual.
It's best to try to match the service manual.   Nonetheless it looks close (are Q4 and Q5 voltages flipped?).  The tone control settings  (or in inaccuracies in the pot tapers) can also cause slight difference unless the service manual says to set them to full or minimum.
QuoteI have also measured DC with shorted input, and this is what I get, but have in mind that my B+ is 23.7V, not 25:
The DC voltages are fairly close.  Nothing stands out as bad (your Q1 base voltage is low due to meter loading).  I checked a few voltages with hand calculations and the service manual voltages look like the transistors have a gain of about 400.
So maybe the problem is the gyrator circuit.  That connects to Q5 so it could be affecting the waveforms.   If the gyrator opamps are clipping it could do something like that.     If you have a real inductor you could try that just see if it gets rid of the flipped waveform peak.  You could also look at the DC voltages and waveforms on the gyrator opamps.
Are all the electrolytic caps loaded with the correct polarity?
I don't use electrolytics, I always use 1uF poly for audio path.
But I have almost the same distortion on another unit which has normal inductor. I will see it with CRO.
QuoteBut I have almost the same distortion on another unit which has normal inductor. I will see it with CRO.
A couple of things to try:
- change the Vari-mid frequency switch to see if it change the waveform shape.   The idea here is perhaps the mid control resonance is making the waveform look weird when the transistor stage clips.
-  It's probably worthwhile lifting the 2x6.8uF caps to isolate the transistor and mid control and see if the inverted tip is present with only the Q5 transistor stage.
Even when mid control completely disabled, there's the same distortion as before (and maybe even more). So it seems that one's not causing it.
Here is ltspice model of Acoustic 360 preamp, no idea what's going on.  :icon_redface:
Version 4
SHEET 1 4708 680
WIRE 272 -208 160 -208
WIRE 384 -208 272 -208
WIRE 496 -208 384 -208
WIRE 1200 -208 496 -208
WIRE 1392 -208 1200 -208
WIRE 1584 -208 1392 -208
WIRE 2048 -208 1584 -208
WIRE 2496 -208 2048 -208
WIRE 2576 -208 2496 -208
WIRE 272 -192 272 -208
WIRE 2048 -176 2048 -208
WIRE 1200 -160 1200 -208
WIRE 2752 -160 2752 -192
WIRE 32 -144 32 -160
WIRE 160 -144 160 -208
WIRE 384 -144 384 -208
WIRE 3248 -128 3152 -128
WIRE 272 -112 272 -128
WIRE 1584 -112 1584 -208
WIRE 2496 -96 2496 -208
WIRE 3152 -96 3152 -128
WIRE 3168 -96 3152 -96
WIRE 3248 -80 3248 -128
WIRE 3248 -80 3232 -80
WIRE 3344 -80 3248 -80
WIRE 3504 -80 3408 -80
WIRE 3552 -80 3504 -80
WIRE 2752 -64 2752 -80
WIRE 2896 -64 2752 -64
WIRE 3120 -64 2960 -64
WIRE 3168 -64 3120 -64
WIRE 1392 -48 1392 -208
WIRE 2048 -48 2048 -96
WIRE 2192 -48 2048 -48
WIRE 2432 -48 2192 -48
WIRE 32 -32 32 -64
WIRE 160 -32 160 -64
WIRE 2752 -32 2752 -64
WIRE 3504 -32 3504 -80
WIRE 1856 -16 1728 -16
WIRE 3120 -16 3120 -64
WIRE 384 0 384 -64
WIRE 416 0 384 0
WIRE 496 0 496 -208
WIRE 496 0 480 0
WIRE 1200 0 1200 -80
WIRE 1328 0 1200 0
WIRE 2048 16 2048 -48
WIRE 496 64 496 0
WIRE 1488 64 1472 64
WIRE 1584 64 1584 -32
WIRE 1584 64 1568 64
WIRE 1728 64 1728 -16
WIRE 1728 64 1584 64
WIRE 1760 64 1728 64
WIRE 1856 64 1824 64
WIRE 1888 64 1856 64
WIRE 1968 64 1968 -48
WIRE 1968 64 1952 64
WIRE 1984 64 1968 64
WIRE 3504 64 3504 48
WIRE 2496 80 2496 0
WIRE 2560 80 2496 80
WIRE 2752 80 2752 48
WIRE 2752 80 2624 80
WIRE 1728 96 1728 64
WIRE 1856 96 1856 64
WIRE 16 112 -16 112
WIRE 64 112 16 112
WIRE 240 112 144 112
WIRE 272 112 240 112
WIRE 384 112 384 0
WIRE 384 112 336 112
WIRE 432 112 384 112
WIRE 2192 112 2192 96
WIRE 2320 112 2192 112
WIRE 2192 128 2192 112
WIRE 3024 128 2960 128
WIRE 3664 128 3024 128
WIRE 16 144 16 112
WIRE 1584 144 1584 64
WIRE 3024 160 3024 128
WIRE 2496 176 2496 80
WIRE 2560 176 2496 176
WIRE 2688 176 2624 176
WIRE 496 192 496 160
WIRE 528 192 496 192
WIRE 656 192 592 192
WIRE 672 192 656 192
WIRE 848 192 832 192
WIRE 880 192 848 192
WIRE 992 192 960 192
WIRE 1104 192 1072 192
WIRE 1200 192 1200 0
WIRE 1200 192 1168 192
WIRE 1392 192 1392 48
WIRE 1408 192 1392 192
WIRE 1472 192 1472 64
WIRE 1520 192 1472 192
WIRE 3664 192 3664 128
WIRE 1728 224 1728 176
WIRE 1760 224 1728 224
WIRE 1856 224 1856 176
WIRE 1856 224 1824 224
WIRE 2688 224 2688 176
WIRE 2320 240 2320 112
WIRE 384 256 384 112
WIRE 496 256 496 192
WIRE 592 256 592 192
WIRE 656 256 656 192
WIRE 1856 256 1856 224
WIRE 3024 256 3024 240
WIRE 3120 256 3120 64
WIRE 3120 256 3024 256
WIRE 3168 256 3120 256
WIRE 3280 256 3248 256
WIRE 3312 256 3280 256
WIRE 3424 256 3376 256
WIRE 3552 256 3424 256
WIRE 16 272 16 224
WIRE 1040 272 976 272
WIRE 1200 272 1200 192
WIRE 1200 272 1120 272
WIRE 240 288 240 112
WIRE 3024 288 3024 256
WIRE 3040 288 3024 288
WIRE 3552 288 3552 256
WIRE 3120 304 3120 256
WIRE 3120 304 3104 304
WIRE 3424 304 3424 256
WIRE -112 320 -112 256
WIRE -80 320 -80 304
WIRE -80 320 -112 320
WIRE -48 320 -80 320
WIRE 848 320 848 192
WIRE 880 320 848 320
WIRE 976 320 976 272
WIRE 976 320 944 320
WIRE 1136 320 976 320
WIRE 2496 320 2496 176
WIRE 3040 320 2976 320
WIRE 848 336 848 320
WIRE 2048 336 2048 112
WIRE 2112 336 2048 336
WIRE 2192 336 2192 288
WIRE 2192 336 2176 336
WIRE 2688 336 2688 304
WIRE 2816 336 2688 336
WIRE -80 352 -80 320
WIRE 3664 352 3664 256
WIRE 1728 368 1728 224
WIRE 1760 368 1728 368
WIRE 1856 368 1856 336
WIRE 1856 368 1824 368
WIRE 2688 368 2688 336
WIRE 1392 384 1392 192
WIRE 1584 384 1584 240
WIRE 160 400 160 384
WIRE 160 400 96 400
WIRE 1200 400 1200 368
WIRE 3424 400 3424 384
WIRE 3424 400 3312 400
WIRE 3536 400 3536 352
WIRE 3536 400 3424 400
WIRE 160 416 160 400
WIRE 1856 416 1856 368
WIRE 2048 416 2048 336
WIRE 2320 416 2320 320
WIRE 3280 416 3280 256
WIRE 3312 416 3312 400
WIRE -80 432 -160 432
WIRE -32 432 -80 432
WIRE 656 432 656 320
WIRE 848 432 848 416
WIRE 3424 432 3424 400
WIRE -32 448 -32 432
WIRE -32 512 -80 512
WIRE 96 512 96 480
WIRE 160 512 160 480
WIRE 160 512 96 512
WIRE 240 512 240 352
WIRE 240 512 160 512
WIRE 384 512 384 336
WIRE 384 512 240 512
WIRE 496 512 496 336
WIRE 496 512 384 512
WIRE 592 512 592 336
WIRE 592 512 496 512
WIRE 1200 512 1200 480
WIRE 1200 512 592 512
WIRE 1392 512 1392 464
WIRE 1392 512 1200 512
WIRE 1584 512 1584 464
WIRE 1584 512 1392 512
WIRE 1856 512 1856 496
WIRE 1856 512 1584 512
WIRE 2048 512 2048 496
WIRE 2048 512 1856 512
WIRE 2320 512 2320 480
WIRE 2320 512 2048 512
WIRE 2496 512 2496 400
WIRE 2496 512 2320 512
WIRE 2688 512 2688 448
WIRE 2688 512 2496 512
WIRE -80 528 -80 512
WIRE 240 528 240 512
WIRE 3296 528 3296 480
WIRE 3424 528 3424 512
WIRE 3424 528 3296 528
WIRE 3456 528 3424 528
WIRE 3568 528 3568 352
WIRE 3568 528 3536 528
WIRE 3664 528 3664 432
WIRE 3664 528 3568 528
FLAG 16 272 0
FLAG 240 528 0
FLAG 160 -32 0
FLAG 2816 336 Out1
IOPIN 2816 336 Out
FLAG -80 528 0
FLAG -160 432 V
FLAG 272 -112 0
FLAG 2576 -208 B+
FLAG 2320 48 IND
FLAG 3072 336 0
FLAG 2960 128 IND
FLAG 3264 448 0
FLAG 3584 320 0
FLAG 2976 320 V
FLAG 32 -160 9V
FLAG 32 -32 0
FLAG 3200 -48 0
FLAG 3504 64 0
FLAG 3552 -80 Out
IOPIN 3552 -80 Out
FLAG 2752 -192 0
FLAG -80 304 OP
FLAG 3200 -112 OP
FLAG 3328 448 OP
FLAG 3072 272 OP
FLAG 3520 320 OP
FLAG -112 256 9V
FLAG -48 256 B+
FLAG -16 112 IN
IOPIN -16 112 In
SYMBOL voltage 16 128 R0
WINDOW 123 24 124 Left 2
WINDOW 39 0 0 Left 2
SYMATTR Value2 AC ac 1.
SYMATTR InstName V1
SYMATTR Value SINE(0 .1 100)
SYMBOL res 160 96 R90
WINDOW 0 0 56 VBottom 2
WINDOW 3 32 56 VTop 2
SYMATTR InstName R1
SYMATTR Value 22k
SYMBOL cap 224 288 R0
SYMATTR InstName C1
SYMATTR Value 220p
SYMBOL cap 336 96 R90
WINDOW 0 0 32 VBottom 2
WINDOW 3 32 32 VTop 2
SYMATTR InstName C2
SYMATTR Value 1µ
SYMBOL res 400 352 R180
WINDOW 0 36 76 Left 2
WINDOW 3 36 40 Left 2
SYMATTR InstName R2
SYMATTR Value 4Meg7
SYMBOL cap 480 -16 R90
SYMATTR InstName C3
SYMATTR Value 100p
SYMBOL res 400 -48 R180
SYMATTR InstName R3
SYMATTR Value 1Meg
SYMBOL voltage 160 -160 R0
WINDOW 123 0 0 Left 2
SYMATTR InstName V2
SYMATTR Value {x}
SYMBOL res 512 352 R180
SYMATTR InstName R5
SYMATTR Value 100k
SYMBOL cap 592 176 R90
SYMATTR InstName C4
SYMATTR Value 1µ
SYMBOL res 608 352 R180
SYMATTR InstName R6
SYMATTR Value 91k
SYMBOL cap 672 320 R180
WINDOW 0 24 56 Left 2
WINDOW 3 24 8 Left 2
SYMATTR InstName C5
SYMATTR Value 10n
SYMBOL res 736 208 R270
WINDOW 0 32 56 VTop 2
WINDOW 3 0 56 VBottom 2
SYMATTR InstName Volume1
SYMATTR Value {Rvol}
SYMBOL res 864 208 R270
SYMATTR InstName Volume2
SYMATTR Value {50k-Rvol}
SYMBOL res 1088 176 R90
SYMATTR InstName R7
SYMATTR Value 8k2
SYMBOL cap 1168 176 R90
SYMATTR InstName C6
SYMATTR Value 1µ
SYMBOL res 1136 256 R90
SYMATTR InstName R8
SYMATTR Value 2Meg7
SYMBOL cap 944 304 R90
SYMATTR InstName C7
SYMATTR Value 1µ
SYMBOL res 864 432 R180
SYMATTR InstName R9
SYMATTR Value 2k2
SYMBOL res 1216 496 R180
SYMATTR InstName R10
SYMATTR Value 680
SYMBOL res 1216 -64 R180
SYMATTR InstName R11
SYMATTR Value 10k
SYMBOL npn 1328 -48 R0
SYMATTR InstName Q3
SYMATTR Value BC550C
SYMBOL res 1408 480 R180
SYMATTR InstName R12
SYMATTR Value 10k
SYMBOL cap 1472 176 R90
SYMATTR InstName C8
SYMATTR Value 1µ
SYMBOL npn 1520 144 R0
SYMATTR InstName Q4
SYMATTR Value BC550B
SYMBOL res 1472 80 R270
SYMATTR InstName R13
SYMATTR Value 270k
SYMBOL res 1600 -16 R180
SYMATTR InstName R14
SYMATTR Value 3k9
SYMBOL res 1600 480 R180
SYMATTR InstName R15
SYMATTR Value 680
SYMBOL res 2704 464 R180
SYMATTR InstName Master
SYMATTR Value 50k
SYMBOL res 1744 192 R180
SYMATTR InstName R16
SYMATTR Value 10k
SYMBOL cap 1824 48 R90
SYMATTR InstName C9
SYMATTR Value 2n7
SYMBOL res 1872 192 R180
SYMATTR InstName R17
SYMATTR Value 25k
SYMBOL cap 1824 208 R90
SYMATTR InstName C10
SYMATTR Value 1µ
SYMBOL cap 1952 48 R90
SYMATTR InstName C11
SYMATTR Value 1µ
SYMBOL npn 1984 16 R0
SYMATTR InstName Q5
SYMBOL res 1952 -32 R270
SYMATTR InstName R18
SYMATTR Value 1Meg
SYMBOL res 2064 -80 R180
SYMATTR InstName R19
SYMATTR Value 4k7
SYMBOL res 1872 352 R180
SYMATTR InstName R20
SYMATTR Value 25k
SYMBOL res 1872 512 R180
SYMATTR InstName R21
SYMATTR Value 680
SYMBOL cap 1824 352 R90
SYMATTR InstName C12
SYMATTR Value 470n
SYMBOL res 2064 512 R180
SYMATTR InstName R22
SYMATTR Value 2k2
SYMBOL npn 2432 -96 R0
SYMATTR InstName Q6
SYMBOL cap 2208 16 R180
SYMATTR InstName C13
SYMATTR Value 6µ8
SYMBOL res 2208 112 R180
SYMATTR InstName R23
SYMATTR Value 25k
SYMBOL res 2208 224 R180
SYMATTR InstName R24
SYMATTR Value 25k
SYMBOL res 2208 304 R180
SYMATTR InstName R25
SYMATTR Value 680
SYMBOL cap 2112 352 R270
WINDOW 0 32 32 VTop 2
WINDOW 3 0 32 VBottom 2
SYMATTR InstName C14
SYMATTR Value 6µ8
SYMBOL res 2512 416 R180
SYMATTR InstName R27
SYMATTR Value 10k
SYMBOL cap 2624 160 R90
SYMATTR InstName C16
SYMATTR Value 1µ
SYMBOL res 2704 320 R180
SYMATTR InstName R28
SYMATTR Value 1
SYMBOL res -64 448 R180
SYMATTR InstName R4
SYMATTR Value 47k
SYMBOL res -64 528 R180
SYMATTR InstName R29
SYMATTR Value 47k
SYMBOL cap -16 512 R180
SYMATTR InstName C17
SYMATTR Value 10µ
SYMBOL cap 288 -128 R180
SYMATTR InstName C18
SYMATTR Value 100µ
SYMBOL cap 2304 416 R0
SYMATTR InstName C15
SYMATTR Value {Cfx}
SYMBOL ind 2304 224 R0
SYMATTR InstName L1
SYMATTR Value 1H5
SYMATTR SpiceLine Rser=240
SYMBOL Opamps\\LT1057 3072 240 R0
SYMATTR InstName U3
SYMBOL res 3008 144 R0
SYMATTR InstName R35
SYMATTR Value 100k
SYMBOL Opamps\\LT1057 3360 448 R90
SYMATTR InstName U5
SYMBOL Opamps\\LT1057 3488 320 R270
SYMATTR InstName U6
SYMBOL res 3440 400 R180
SYMATTR InstName R40
SYMATTR Value 1k
SYMBOL res 3440 528 R180
SYMATTR InstName R41
SYMATTR Value 1k
SYMBOL res 3552 512 R90
SYMATTR InstName R42
SYMATTR Value 1k
SYMBOL cap 3312 272 R270
SYMATTR InstName C22
SYMATTR Value 1µ
SYMBOL res 3264 240 R90
SYMATTR InstName R43
SYMATTR Value 1k
SYMBOL cap 3648 192 R0
SYMATTR InstName C25
SYMATTR Value {Cfx}
SYMBOL voltage 32 -160 R0
SYMATTR InstName V3
SYMATTR Value 9
SYMBOL Opamps\\LT1057 3200 -144 R0
SYMATTR InstName U1
SYMBOL res 3520 64 R180
SYMATTR InstName Load
SYMATTR Value 10K
SYMBOL res 3104 -32 R0
SYMATTR InstName R26
SYMATTR Value 1Meg
SYMBOL cap 3344 -64 R270
SYMATTR InstName C20
SYMATTR Value 4µ7
SYMBOL res 2768 64 R180
SYMATTR InstName R30
SYMATTR Value 18k
SYMBOL res 2768 -64 R180
SYMATTR InstName R31
SYMATTR Value 5k6
SYMBOL cap 2624 64 R90
SYMATTR InstName C19
SYMATTR Value 2µ2
SYMBOL cap 2960 -80 R90
SYMATTR InstName C21
SYMATTR Value 100n
SYMBOL res 176 400 R180
SYMATTR InstName R32
SYMATTR Value 1Meg
SYMBOL cap 144 416 R0
SYMATTR InstName C23
SYMATTR Value 4n7
SYMBOL res 112 496 R180
SYMATTR InstName R33
SYMATTR Value 220k
SYMBOL res 3648 336 R0
SYMATTR InstName R34
SYMATTR Value 240
SYMBOL res 656 208 R270
SYMATTR InstName R36
SYMATTR Value 1
SYMBOL npn 1136 272 R0
SYMATTR InstName Q2
SYMBOL npn 432 64 R0
SYMATTR InstName Q1
TEXT 600 -160 Left 2 !.tran 0 .5 .4
TEXT 600 -128 Left 2 !;.ac oct 16 10 50k
TEXT 600 -96 Left 2 !.param x 23.6
TEXT 600 -64 Left 2 !;step param x list 18 25 35
TEXT 600 64 Left 2 ;http://sound.whsites.net/articles/gyrator-filters.htm
TEXT 744 552 Left 2 !;.step param Cfx list 8n2 12n 15n 27n 39n 56n 100n 220n 470n 1u 2u2
TEXT 600 -32 Left 2 !.param Cfx 1u
TEXT 600 0 Left 2 !;.step param Rvol 1 49k99 10k
TEXT 952 0 Left 2 !.param Rvol 1
QuoteEven when mid control completely disabled, there's the same distortion as before (and maybe even more). So it seems that one's not causing it.
That's good.   So it can only come from that stage.
So maybe the next step is to drive the input of the tone control directly with a signal generator.   That will isolate that transistor stage entirely.
QuoteHere is ltspice model of Acoustic 360 preamp, no idea what's going on.
Unfortunately I'm not running my engineering computer at the moment so I can do any spice sims.   I would be nice to see the spice sim.  If it shows up in the idealized environment of spice then it's a real effect.
Normally weird things like negative tip you are seeing are related to caps charging up.   What I'm saying here is the flipped peak is actually a cap charging up in the positive direction. There's only the input cap and the tone control caps.
To charge the input cap it must come from:
- the transistor, which doesn't make sense under normal circumstances since the BE junction doesn't supply current.  If the BE junction broke down it could supply current but the voltages are too low.
- from the CB feedback resistor.  The CB resistor look too large to charge up a cap in that time and produce the  peak.
So the only think that makes sense is a tone control cap control is charging up.  That's where a spice sim would help.   That effect would show-up reliably in spice.
Another thought is  the flat-top on your signal generator going through the EQ of the tone control is promoting an odd-shaped waveform.   You could try smoothing the output of your generator with an RC filter with a 300Hz cut-off.   Alternatively just use your PC as a signal generator.  That will give a clean sine output.
(BTW.  you can often fixed distortion on sine-wave oscillators by tweaking the gain of the amplifier used in the oscillator.  Lowering the gain lowers the hardness of the clipping and that cleans up the waveform.)
But Rob, all of my caps are non-polarized, metal film, except those with 6u8. I disconnected this varitone by simply removing the inductor, but they are oriented just as they shall be.
And this is the distortion of generated signal. It's too complicated for me to make a good CRO shot while playing a guitar, so I used generator. However, it's distorted regardless signal source.
And in spice it simply works normal - at least I think it does.
Quote from: Rob Strand on February 23, 2020, 06:28:04 PM
Which one? The one before the tone stack or the one after it?
QuoteBut Rob, all of my caps are non-polarized, metal film, except those with 6u8. I disconnected this varitone by simply removing the inductor, but they are oriented just as they shall be.
Ideally you want to pull both the caps.  If you just pull the inductor part there is still a feedback circuit from the collector to the emitter via the two caps and the pot.   That could be doing *something* to the emitter voltage.
Pulling the inductor part does confirm the it's not cause by the gyrator or presence of the inductor.
When you get weird problems it's a good policy to strip everything back to the bare minimum so there's nothing else to blame - even if you think a lot of stuff can't possibly cause the issue.  If you strip a circuit back to two resistors and it's not doing what you expect then you have a very good chance of seeing what the problem is.
QuoteAnd in spice it simply works normal - at least I think it does.
That's very odd then.  Try different input levels.  You need to match the tone control pot settings is spice.
You could just replace transistor Q5.
Unfortunately I don't have spice running otherwise I would have tried to break the circuit ages ago.
Yes that one.  The stage with Q5.
