morley pro series wah volume put a 3dpt
Started by arkham, March 05, 2020, 01:35:08 PM
arkham
hi
i ve a old morley wah volume  ( build in 1997) and i heard a problem on, when it s off, it's filtering the sound in treble
so i want to put on a 3dpt but I do not know which cable to weld and where
can you help me
antonis
arkham
#3
it s work and not, the true bypasse don t work, but the effecct yes, and i think it s coming for the schema cause it s not the good
my wah is the version of 1997 , i put the schem here  if you have a solution
antonis
Can't see any difference on IN-OUT wiring fορ both schematics..
If effect works, it means you've wired correctly IN, OUT & GND so check for proper IN & OUT sleeves grounding in by-pass mode..
(I presume you use stereo plugs - at least, for INPUT..)
P.S.
Forgot to tell you about LED- red wire on the lower left side of 3PDT switch which corresponds to status indicator LED cathode and has nothing to do with any other LED appearing on schematics..
