Help with tone sucker
Started by whomeno, May 15, 2020, 09:09:30 PM
whomeno
I'm tring to build the tone sucker amp from "pual in the lab". Got the board done, but now I'm not sure how to hook the transformer up to it.
I bought a hammond  BE2G 24V transformer.
I see there is 2 ac inputs  and a ground on the board. so the hot and common would go to the ac inputs? correct and where would I connect the ground wire from the board?
And the schmatic
Asking for the guru's to help me out a little on setting this up.
Gear as of now
Gibson 2017 Les Paul Tribute T
Epiphone Les paul Special (upgraded)
Marshall DSL 20 Head
Peavy Valve king 20 W
2 X 12 Cabinet with celestion vintage 30 & celestion G12T-75
And a lot of pedals
willienillie
The start and finish of the 24VAC secondary go to AC1 and AC2.  If there is a center tap don't connect it, a bridge rectifier doesn't use a CT.  Board ground would connect to common ground for the whole circuit, along with jack sleeves etc.
antonis
Sorry but I think that you either kidding us or post & forget/ignore your issues..
https://www.diystompboxes.com/smfforum/index.php?topic=124449.0
whomeno
Thanks for the reply and yes I forgot I posted earlier.
Gear as of now
And a lot of pedals
iainpunk
in the schematic, the 7808 has two of the same value capacitors in front and after it, although this will probably work alright for you, it's good practice to have different value capacitors to prevent the chip from oscillating and getting hotter than it's supposed to be. i had a 7805 that burned up because of oscillations. i suggest a 22n in front and the original 10n after.
cheers,
Iain
cheers
whomeno
Ok  1 last question on this amp. it calls for a 22K pot. auto or linear taper? I don't have a 22K what would be a good value to go with.
Gear as of now
And a lot of pedals
25K should be fine.  22K is a Europe thing.  And I would guess at log.  Though the pin designation on the schematic looks just plain wrong - it goes from grounding the output from the preamp to grounding the input to the power amp!  Not checked vs. the layout, because not enough coffee...
antonis
#7
Just a question..
In case of you don't feed another circuit from 317 output (like clearly seen on schematic), what's the reason for using 32.5VDC rectified power to get only 8V from 7808 output..??
As for Volume pot, I totally agree with Eric (and I already have enough coffee..)
(also checked and verified vs layout..) :icon_wink:
whomeno
Bluebunny.
Can you explain more please? The amp seems to work but hardly any volume.
Gear as of now
And a lot of pedals
antonis
Still coffee time for Bluebunny.. :icon_wink:
Lug 2 (wiper) of Volume pot is permanently grounded..
So, despite of its setting, signal goes to Ground 'cause it's the way of less resistance..
Even in max setting (no resistance between wiper & lug 3) there is some resistance of the following circuit "seen" by signal when sitting on lug 3..
(signals are lazy enough to follow the hard way..) :icon_wink:
whomeno
#10
antonis,
Is there a way to fix this? The amp dose work but has low volume, I think the tda2030 is bad. would the grounding of lug 2 and 3 cause low volume?
I am looking at the vero, where is pin 2 grounded at?
Gear as of now
And a lot of pedals
antonis
I suppose so..
On layout, replace 22K 1 for 22K 2, 22K 3 for 22K 1 and 22K 2 for 22K 3
Wait a minute 'cause your layout is wrong ..
antonis
22K-2 is OK..
22K-3 should go On negative leg of C9..(where 22K-1 wrongly goes..)
22K-1 shoulds go to any convenient GND (like where 22K-3 wrongly goes..)
So, just interchange lus 3 & 1 .. :icon_wink:
(my poor eyes hurt..) :icon_redface:
whomeno
Gear as of now
And a lot of pedals
Quote from: antonis on May 20, 2020, 07:11:53 AM
Yep, this is what I was getting at, but without the benefit of caffeine.   :icon_wink:
whomeno
Update... The tda2030 was bad found a tda 2040 i had put it in and sounds good.
Gear as of now
And a lot of pedals
niektb
This design bugs me also  :o
If you have a trafo, why not using double-sized (positive and negative) supply? Now you have to put DC-blocking caps and biasing resistors everywhere  ???
And 2200 uF on the output  :o
antonis
Quote from: niektb on May 21, 2020, 02:24:31 AM
Good design practice for output of single supply power amp..
(although some experts claim for super-extra-high quality/cost of particular cap..) :icon_wink:
On a second look, it indeed is a quirky design..
e.g. Zobel network (Boucherot Cell) R10/C13 values are aimed at some "extra-ordinary" loudspeaker..
