Question re: Piggybacking functions in an effects box
Started by Guitarist335, July 25, 2020, 11:12:54 AM
Guitarist335
I have a design question. If you have built an overdrive pedal using IC chips etc, is it possible to combine it with a delay feature?
In other words, is is possible to build a two stage pedal
Stage 1 generates the overdrive/distortion
Stage 2 adds delay
If so, does anyone have a schematic that would show this? Prefreably, is there a drawiong that could be used to build stage 2 and add it on to any stage 1 circuit?
Thank-you
GibsonGM
There are many ways to wire up your effects, and your idea is certainly not uncommon!
Look here, scroll down to "Multi Effects Switching"....
http://www.generalguitargadgets.com/how-to-build-it/technical-help/switching-and-wiring/bypass-sw-options/
