Back again with a Aion corvus
Started by whomeno, September 08, 2020, 06:36:02 PM
whomeno
I got the corvus pcb today. got it done, but it has low volume. you have to max the volume. I used for IC1 4558. For IC2 I tried a ua741 and a tlo71. same thing no chage. This has an option to use IC3 for a dual opamp so I tried a 4558 in IC3. same thing no change.so I probed it. I got good tone going to R8-8.2K, but loose it coming out of the IC2. I will attach the build doc along with pics. the build doc has the schematic in it. I am NOT having a good day. Or dose this pedal behave like this, you have to max the volume?
the link to build doc
https://www.dropbox.com/s/l3x7vvmvbaeerg9/aion-corvus-ehx-big-muff-pi-opamp-documentation.pdf?dl=1
Voltage 9 Volt
4558
1  4.29 V
2  4.31 V
3  4.27 V
4  0 v
5  4.28 v
6  4.37 v
7  4.41 v
8  8.69 v
TLO71
1  .014 v
2  4.74 v
3  4.56 v
4  0 v
5  .014 v
6  4.85 v
7  8.69 v
8  0 v
Gear as of now
Gibson 2017 Les Paul Tribute T
Epiphone Les paul Special (upgraded)
Marshall DSL 20 Head
Peavy Valve king 20 W
2 X 12 Cabinet with celestion vintage 30 & celestion G12T-75
And a lot of pedals
Marcos - Munky
Perhaps does the opamp big muff have a low volume output? I mean, this is the 3rd one you built using different layouts, and all of them have the same low volume issue.
If you take a look at the first build report here (https://aionelectronics.com/build-reports/?project=66), it also says about the low volume: "4558 on IC1 + 741 on IC3 = lacks headroom. I had to turn the volume knob all the way up to try to match my guitar's clean volume."
whomeno
That is what i thought also. I have yet to find a loud muff.
Gear as of now
And a lot of pedals
Marcos - Munky
The regular transistor muffs are pretty loud. The same comment on the opamp muff said different opamps gave louder or quieter output volumes, so it's worth to give a try on different opamps.
whomeno
Gear as of now
And a lot of pedals
bushidov
#5
It would be a slight redesign of the circuit, but you could do what the transistor big muffs do and add a "recovery stage" at the end of the circuit. Essentially adding something similar to an LPB-1 after the pedal.
"A designer knows he has achieved perfection not when there is nothing left to add, but when there is nothing left to take away."
- Antoine de Saint-Exupéry
antonis
#6
What Erik said..  :icon_wink:
"Standard" Big Muff Tonestack develops about -13dB signal attenuation resulting into a 1/5th of that coming out of last gain stage..
willienillie
"Aion corvus" is almost a perfect anagram of "coronavirus"
WHAT DID THEY KNOW???
aion
Quote from: willienillie on September 09, 2020, 08:00:00 PM
Well... there's also one called the Corona which is a little more on point!
11-90-an
funny that my schem/ckt notebook's brand is corona...
even before corona...
flip flop flip flop flip
willienillie
Marcos - Munky
Quote from: willienillie on September 10, 2020, 06:04:22 AM
Quote from: 11-90-an on September 10, 2020, 12:34:08 AM
(Put my username into the periodic table)
Nathan!
Wow, that was pretty clever! I was guessing how to call 11-90-an, now I know :icon_mrgreen:
whomeno - a question, just curious. are you knocking these builds out by the day, or are you working your way through a box-of-shame builds?
I feel sick.
willienillie
Quote from: Marcos - Munky on September 10, 2020, 08:22:55 AM
Nathan!
We'll have to call him Nathan Jr because we already have a well-established Nathan.  And "Nathan Jr" is from one of my favorite movies.
"Which one did ya get?"
"I don't know, but I think it was Nathan Jr."
bushidov
Quote(Put my username into the periodic table)
Erbium, Iodine, and Potassium?
I feel sick.
