Can I use Zener Diodes Like This?
Started by Ripthorn, November 12, 2020, 08:26:47 PM
Ripthorn
I am using a CD4066 for controlling 4 separate signals. I also want a fifth switch that will provide voltage to all four control pins simultaneously. I tried to isolate control voltages to each control pin using high value resistors (See right hand side of attached image). However, I still get voltage bleed when a single switch is activated, and I don't like needing such large resistors. So I had the thought of using Zener diodes with a voltage rating higher than the DC value that will be applied for the control pins. Can I do that? Is there an issue with having 5V frequently on the cathode side of the Zener? I know what they do in theory, I just don't use them too much. I guess I have used them for over voltage protection, which has almost the voltage rating constantly on the cathode...
So this should work, right?
Exact science is not an exact science - Nikola Tesla in The Prestige
https://scientificguitarist.wixsite.com/home
What you want is an "OR Gate". If "B" OR "All" is high, output is high, else low.
While there are active OR gates, for such a minimal job you can use two diodes and one resistor per input.
