No Flange Signal, Electric Mistress
Started by dfx_pedalpcbs, November 07, 2020, 02:46:57 PM
dfx_pedalpcbs
Where in the signal should there be some flanging going on, is it at pin 7 & 8 of the MN3007 because I get nothing there at all
I get a clean signal at the output just no effect, led flashes at the LFO.
All the chips are good and work in other effects so im not sure whats causing this
iainpunk
do you have an Audio Probe? that is the best tool for debugging.
the flanging only really happens when you mix the clean and pitch shifted delayed signal together. there should be signal on the output of the chip, but is should sound vibrato-like
cheers, Iain
cheers
danfrank
You should have flanging where r15, 16 and 17 come together. If you're using the "send & return" jacks, you need to make sure there is a connection to bridge those two jacks when no 1/4" plugs are inserted into those jacks. If you aren't using those jacks, a wire needs to be soldered to the 2 jack's hots so signal goes through.
Good luck
anotherjim
I'd have thought those send/return jacks should use switched sockets so the signal passes between them when nothing is plugged in.
StephenGiles
What are the clock voltages at pins 2 & 6 of the MN3007? They should both be around half +Vc.
danfrank
Quote from: anotherjim on November 08, 2020, 06:23:34 AM
Yes, I was just trying to cover anything that might be overlooked since the provided schematic doesn't show switched jacks.
dfx_pedalpcbs
Clean signal at those junctions
MN3007
Pin 2-0V
Pin 6-8.75V
danfrank
Pin 2 should be the same voltage as pin 6, the other clock pin.
Probably a solder bridge or cold joint on the PCB or there's something wrong with the clock pulses going to pin 2 of the 3007
StephenGiles
#8
Quote from: danfrank on November 08, 2020, 04:12:47 PM
Also remove the 3007 and see if the voltages going to its pins 2 & 6 are the same, if they are remove the 4049 and test voltages at pins 1 & 2 of the 4013.
dfx_pedalpcbs
ok will try those steps and report back
dfx_pedalpcbs
#10
MN3007 removed-voltages same
CD4049 removed pin 1 on the CD4013 is 8.75V and pin 2 reads nothing
Tried different LM311 and its now working
Thanks for the help
StephenGiles
Good news, I was leaving the 311 until last because I don't know how available they are!
If LM311 goes away, that's the end of the world.
DigiKey shows lots. Limiting to DIP ThruHole, over 9k in stock, under a buck a chip. If you like lead, that's half price.
We OK for today.
StephenGiles
Quote from: PRR on November 10, 2020, 11:24:41 PM
We OK for today.
That's good to know should I run out!
dfx_pedalpcbs
This was the batch that gave me head aches!
danfrank
Where did you purchase them? It's always good to know where to avoid difficult parts. Thanks
dfx_pedalpcbs
ebay but sorry I cant remember the seller
