Comet (DS-1) : crackling issue [SOLVED]
Started by eh la bas ma, May 28, 2021, 09:17:26 PM
eh la bas ma
Hello,
I built a Comet kit and I have some crackling sounds mixed with the distortion.
https://aionfx.com/app/files/docs/comet_legacy_documentation.pdf
Here is an audio sample :
https://soundcloud.com/ehlabas-ma-chaussure/ds1cracklings
(Edit : noises are audible between 0:10' and 0:20', and from 1:04' to 1:15').
I am playing with active pickups. I chose to go with Mod 1 and Mod 2, according to the instructions, page 3. I didn't do the Big Muff mod.
This issue appears to be touch sensitive : when I am strumming the strings softly, there is no noises. There are crackling sounds if I am strumming a little harder .
Also, I noticed the cracklings go away when I turn the guitar volume almost all the way down (audio sample : from 0:30 to 0:50).
I tried this circuit with a RC4558 at first. I noticed the noises and change the IC for a TL72. It sounds a little better but the issue remains almost the same.
I never played on a DS1 before, or I don't remember it.
I wonder if it could be something to be expected from the circuit (with active pickups) ?
Any help would be welcome !
"One Cannot derogate, by particular conventions, from the Laws which relate to public Order and good Morals." Article 6 of the Civil Code.
"We must not confuse what we are and what society has made of us." Theodor W. Adorno.
antonis
Quote from: eh la bas ma on May 28, 2021, 09:17:26 PM
No crackling sounds at all..
Just the "normal" sound of a quirky design.. :icon_wink:
eh la bas ma
#2
I don't know if crackling is the right word : I would like to remove the noises that you can hear between 0:10' and 0:20', and from 1:04' to 1:15', if it is possible.
From 0:30 to 0:50, I turned the guitar's volume down and the noises are gone, isn't it a sign that there might be some kind of impedance trouble ?
This circuit sounds very good to my ears if I ignore the noises.  I built a few stompboxes with Aion's pcb, and they were all flawless, as far as I can tell.
Could the modifications 1 & 2 suggested in the instructions be the cause of this issue ? By "quirky design" do you mean that this kind of noises have been willingly added to the distortion, as a "good" thing ?
antonis
Quote from: eh la bas ma on May 29, 2021, 03:52:49 PM
Can't tell about "willingly" but I shouldn't feed a Big Muff gain stage via a buffer.. :icon_wink:
(if it was on breadboard, I'd suggest you to place a 10k (or so) resistor between C2 & Q1 Base..)
eh la bas ma
#4
Thanks, I'll try your suggestion and report back.
About the buffer, I am not sure I understand what you mean :
"The circuit remained unchanged until 1994, when it was modified to use the new PSA adapter instead of the old ACA. In the process, the op-amp was changed from a single to a dual—still the SIL (single-in-line) form factor, but the circuit was also revised to take advantage of this newly-available op amp, and a unity-gain buffer was placed in front of the adjustable gain stage. "
source : https://aionfx.com/project/comet-legacy/
Also this video, from Mr Wampler comparing SD1 and DS1 circuits, confirms that there should be a buffer just after the input (2:21).
https://www.youtube.com/watch?v=tpLms92E5qE
eh la bas ma
It sounds like it's fixed.
My values on C1 and C2 were wrong : 100n instead of 47n.
Thanks and sorry for my thoughtlessness...
Great sound !
ThermionicScott
Awesome, great to hear the rest of the story.  :icon_cool:
"...the IMD products will multiply like bacteria..." -- teemuk
antonis
Quote from: eh la bas ma on May 29, 2021, 07:16:14 PM
Never mind.. :icon_wink:
If it works by halving HPF (wrong) cap values, let it be..
