Wich Switch for a simples toggle between clipping mods.
Started by mateusborges, June 04, 2021, 12:31:59 AM
mateusborges
Hello there guys!!
New question. A want a switch that allows me sellecting 3 option of clipping.
Think the TS808, I want to add a toggle that woud allow me sellecting between 3 types of diodes in the 1st position, like a 4001, a 914 and a 4148, or even a led, then same thing for the 2nd stage and at the end another one for selecting 2 assyncronous configurations and a jumper leaving only the syncronous one.
What switch I need? rocker swith with on off on and 6 pins?
antonis
Just a SPDT (ON-OFF-ON) one for each pair of clipping diodes..
(diode pair with higher forward voltage drop permanently connected..)
nocentelli
If you can get a DPDT on-on-on selector switch, you can wire it as a 3PST switch (i.e. with one common connection toggled between three different connections):
