Is anyone able to identify a replacement 3.5mm PCB mount, 3-contact jack?
Started by laundryman, June 18, 2021, 01:48:16 AM
laundryman
Link to photos: https://imgur.com/gallery/slEGyXx
I pulled out an old Furman SPB-8 pedalboard and two of the 3.5mm PCB mounted jacks for 9V pedal power were snapped off at 2 of the 3 the leads.
I looked around online but I'm hoping to make sure whatever I order to solder on is the right size and lines up with the PCB mount holes.
Or if anyone knows of a way to reuse the two with broken leads that would be even better.
