-9V DC supply for PNP based fuzz
Started by StingRay85, July 05, 2021, 09:08:12 AM
StingRay85
Hello,
New member here. Last week I build a Rangemaster clone, and I think I caught the microbe of working on these Ge transistors.
When I was looking for a chassis for a new project, I found a Geloso G300V preamp, that works either on AC or 9V battery. It uses 4x AC107 and a single AC126 transistor. It has positive ground, meaning that the tiny transformer inside the unit has a diode bridge rectifier to produce -9V as + is sent to ground. Is there any downside of using this power supply for a tone bender or fuzz face type of preamp?
I just build to learn and experiment at this point.
Cheers
antonis
Hi and Welcome.. :icon_wink:
Quote from: StingRay85 on July 05, 2021, 09:08:12 AM
Could you plz post a schematic 'cause I'm confused a bit..
(negative rectification..??)
edit: Never mind..!!
Yes, you can use it as well..
