Buffer voltage question
Started by Esppse, July 12, 2021, 01:18:09 PM
Esppse
Hello,
If I put 12V into the smallest buffer here:
https://tagboardeffects.blogspot.com/2014/08/buffers.html?m=1
Will it run OK, or do I need to alter some resistor values? It's going to be on a board with a drive using 12V, and I was just curious if it is OK as is.
Make sure your capacitors are rated for at least 16V and you'll be fine as is.
Esppse
