Colorsound Fuzz wiring question
Started by usurp, August 17, 2021, 05:42:05 PM
usurp
hey all. i am trying to build the colorsound one knob fuzz pedal and this is the first veroboard build i'm doing. i am using this layout;
http://3.bp.blogspot.com/-mCGDpZojvLo/UHi8NFYQPtI/AAAAAAAAC_0/wNt7y6hhyP8/s1600/Colorsound+One+Knob+Fuzz.png
i got all the components on the board but at this point i can't wrap my head around wiring everything together. i am also going off of this diagram for wiring the 3pdt stomp switch;
http://3.bp.blogspot.com/-EU_2EXapXLY/T5_wCJnN9YI/AAAAAAAABDU/xkOXlkmzruY/s400/EZ_3PDT_WIRING.gif
here is what i'm thinking so far;
i think i know where all the cables go but my one question is this; do i connect both ground cables from the input and output jack to the middle lug of the 3pdt switch?
antonis
Any ground wire is more conveniently placed close to the switch.. :icon_wink:
Of course, there should be wiring connection between power supply GND, IN jack sleeve, PCB GND and OUT jack sleeve..
Below is a general wiring diagram.. GNDs are Black, Blue & Purple wires
(3PDT switch is wired for bot IN & OUT grounded when effect bypassed.. you can ignore it and make your simple wiring,,) :icon_wink:
usurp
thanks for the info! im gonna keep this one for future reference for sure! so are you saying that the diagram i posted would work?
antonis
#3
Quote from: usurp on August 17, 2021, 07:36:41 PM
If you're talking about 3PDT switch wiring, YES..!! :icon_wink:
(it might not even need any extra wiring for IN-OUT anti-pop grounding 'cause thery are already grounded via 1M resistor and 500k Volume pot..)
nocentelli
Yes, but you will also need a connection between +9v to a current limiting resistor (e.g. 10k) then on to the LED positive terminal (not shown in your diagram)
