Strange problem Need Help
Started by whomeno, September 26, 2021, 05:50:03 PM
whomeno
just built a EHX double muff. used bc 547c instead of bc550b. when hooked up to my test box v2. nothing when engaged. when I use the probe hooked to my test box, I got good signal at out put of pedal. I found out if I put a 100nf cap at the output of pedal from m1 B100k pin 2 then to test box works fine. checked my test box with a tone generator, the test box passed. So I'm pretty sure it is not the test box. Been going over this for the last 4 hours. I don't know where to look any more. please help before i go insane.
voltages 9 v in
Q1  C 2.2   B  .47  E  0  Q2 C  2.87   B  1.80   E  1.78  Q3  C  1.68   B  .53  E  0  Q4  C  5.08   B  1.68  E  1.10
Gear as of now
Gibson 2017 Les Paul Tribute T
Epiphone Les paul Special (upgraded)
Marshall DSL 20 Head
Peavy Valve king 20 W
2 X 12 Cabinet with celestion vintage 30 & celestion G12T-75
And a lot of pedals
whomeno
Problem solved. it was my test amp. it was working but not right.
Gear as of now
And a lot of pedals
