Choosing JFET for bypass switching
Started by mark2, December 14, 2021, 12:47:47 PM
m4268588
mark2
Thanks for the clarification on the TS, and what happens if it's not biased on both the S&D.
And for the extra info Rob. I'll check those threads out now.
I'm going to be trying out some 2SK208-R for switching by the way. It seems to have a similar VGS(off) as other commonly used JFETs: −0.4 to −5.0V.
m4268588
mark2
Quote from: m4268588 on December 18, 2021, 10:46:11 PM
Vf=0.3 to 0.4V(lower)
I'll spend some more time trying to understand, but can you explain a little more about what you're trying to point out? Thanks!
m4268588
Because there is small current flowing to the diode.
It is good to make a large estimate for safety reasons.
mark2
Large CV? My plan is to use a uC and MOSFET to drive 9V to turn on the JFET, if that's what you mean.
m4268588
Turns "ON" at CV=9V.
Use J-FET with small Vgs as possible.
