PNP Germanium Transistor pinouts?
Started by KerryF, August 03, 2006, 12:42:29 PM
KerryF
Can someone draw me a diagram labeling the pinouts for a PNP Germanium transistor.  I am using these for the ColorSound ToneBender MKII Pro and im not sure where to put the transistors in.  I have 6 of these, because I am building 2 of the ToneBenders.  I have the values of each if thats needed.
markm
Jay Doyle
DIY FAQ link.
Near the bottom are transistor pinouts.
Actually, most of what people ask can be found in there or using a search.
  DMM Hfe checkers do the pinout verification thing well.
  Usually just turning them around once in the socket, PNP side and NPN side too...you probably won't have to twist two of the leads around to get a reasonable reading which shows pinout and polarity, a 'reasonable' [not accurate for calculating gain] Hfe reading.
Torchy
KerryF
Thanks so much everyone.  And Torchy thanks for the diagram!
karsten_h
Quote from: Torchy on August 03, 2006, 01:04:08 PM
I did a quick search and found this thread ...
http://www.diystompboxes.com/smfforum/index.php?topic=44525.msg324038#msg324038
with this picture
... got a couple of OC170 here and i wonder how to use this pinout? is the shield only to be discarded or what?
... just standing on the shoulders of the diy stompbox scene out there.
antonis
turbofeedus
#8
Quote from: karsten_h on January 19, 2022, 10:36:25 AM
with this picture
OC170s can suffer from tin whisker syndrome.
Yee have been warned! :icon_evil:
https://nepp.nasa.gov/whisker/anecdote/af114-transistor/index.html
Quote from: antonis on January 19, 2022, 11:14:02 AM
https://www.diystompboxes.com/smfforum/index.php?topic=21074.0
Last post..
Tin whiskers would explain what saros141 was experiencing. I'm only 17 years too late  ;D
