Modern replacement for TL607 switch IC.
Started by Scruffie, February 05, 2022, 03:59:00 PM
Scruffie
Over in this thread ( https://www.diystompboxes.com/smfforum/index.php?topic=128615.msg1239689#msg1239689 ) for the EH guitar synth, I've modified the original schematic to replace a TL607 switch with standard CMOS and I wondered if anyone could spot any reason why this wouldn't work and if so advise of a more suitable replacement?
Datasheet
https://pdf1.alldatasheet.com/datasheet-pdf/view/87620/TI/TL601.html
Schematic section (Bottom right, circled numbers indicate original pin numbers for the TL607)
Thanks in advance!
Scruffie
Bump, any of you delightful people able to cast an eye?
Edit:No of course it wont work, don't see why I didn't see it before... back to the drawing board.
