ROG Brittania
Started by freshmex18, March 14, 2022, 08:00:26 PM
freshmex18
So I've built this pedal
http://www.runoffgroove.com/britannia.html
using this layout
http://tagboardeffects.blogspot.com/2014/09/rog-britannia.html
and got it working.  It sounds great (if maybe just a little bit too gainy).
The ROG website has the clipping diodes just before Q2 as 4148s but tagboard has them as red LEDs (D3 and D4 on the tagboard layout).  I put the 4148s and the Red LEDs on a switch and I've been going back and forth and I am just not hearing a difference.  What exactly am I supposed to be listening for?  Or is it such a subtle difference that I am not going to hear at bedroom levels it anyway?
radio
As  it  is written in the description of the ROG Britannia , they are limiting the voltage at the gate(s) of the fet stages
Keep on soldering!
And don t burn fingers!
freshmex18
Ah, I misread the text about the red LEDs limiting the other gain stages from clipping too hard but not at Q2.
So then, what is the advantage for choosing the red LEDs before Q2 vs. the 4148s?  I don't notice a gain drop when switching between the two
radio
With the silicon diodes you limit the signal at the gate at about 0.6V versus 1.2V with red leds
Instinctively I would have done the opposite so I can only assume they got a better result
simulating the 2nd triode stage!?
Keep on soldering!
