Help identify this Distortion pcb?
Started by Psychophonic, May 18, 2020, 11:03:16 AM
Psychophonic
Quote from: willienillie on May 21, 2020, 04:19:51 AM
I would recommend one more, since you are swapping pots anyway, make the volume pot an audio taper.
I've decided to re-use the original enclosure for this project, but I'm having a difficult time googling the proper replacement pot. The long flat solder legs, proper shaft length, etc. I couldn't find one at Small Bear or Amazon. Still searching.
victor nery
#21
Greetings,
Here you got it:
On the one I have it's marked as DST-585 rev. A. Board looks exactly the same. So, although similar, it's not a direct clone of the DS-1. For any reason Belcat hates hard clipping. lol
Best regards
"Do what thou wilt shall be the whole law!"
