Questions about feedback looper circuits
Started by eh la bas ma, December 01, 2022, 12:01:37 PM
eh la bas ma
Hello,
A friend was playing solo in a bar last night. It was great. He was doing essentially some tapping on his guitar with both hands, using 2 delays, an overdrive, and a "feedback pedal". Pavel Viry, you can listen to his work on bandcamp.
I'd like to try to build one of these since it looks quite simple.
If I understand correctly, this is supposed to take the wet signal from 1 effect or more, let's say a delay for exemple, and send the signal in the same delay again, and again...?
Is there some interesting feature I could add to this build ?
Edit 1 : My friend told me that his feedback pedal doesn't work with every circuits, he said it's even written in the product's documentation.
Is there some simple explanation about that ?
Edit 2 : I found the same issue at the end of this post :
Quote from: johnnysomersett on July 31, 2009, 11:05:46 AM
You know what, ****-it, I can't be bothered to do anything with the schematic, you can have it:
Spread the love....
** Funnily enough, it's quite dependant on what FX you put into it. My BBE Two-Timer works ace with it, yet my Malekko 600D does absolutely nothing with it!
All ideas are welcome !
"One Cannot derogate, by particular conventions, from the Laws which relate to public Order and good Morals." Article 6 of the Civil Code.
"We must not confuse what we are and what society has made of us." Theodor W. Adorno.
