Accutronics digilog reverb brick question
Started by Colman, May 04, 2023, 09:09:31 PM
Colman
How do I know if my BTDR -2H is burnt or otherwise unusable. :icon_redface:
Aharon
You are not depressed ,you are sourounded by A-Holes: Karl Jung
idy
I think you will want to get the data sheet...
look at the typical circuit, where you put the regulated 5v, where you put signal in, where it comes out...
You probably can leave the opamps (buffers/ mixers) out... Some one else maybe pitch in on that. They are not buffers, they boost a little(?)
and try it out with a signal
+5v (regulated!) to pin 1, Power ground pin 2, 3 input, 4 signal ground, 5 and 6 are outputs.
idy
The input opamp on the example circuit provides bias, you can't just put an audio signal into the input.
Colman
