Aion Vector Delay no sound when switched on
Started by antonis, April 20, 2023, 06:35:38 AM
Muttlyboy
Plus I have a new Aion Vector question...
With the effect turned on, there's a slight volume drop...nothing too terrible,  but I'm wondering if there are any tweaks to boost the volume a slight bit?
antonis
Muttlyboy
Thanks Antonis...
Kevin from Aion got back to and recommended dropping R3
from 22k, to 20k or 18k.
I had a 100k 1/4 watt handy so I put it in parallel with the 22k for 18k result. It seems to have worked.
I need to order some 1/4 resistors. I'm going to try out your idea also. Thanks for the suggestion.
antonis
If it's OK with Kevin's suggestion, don't bother furthermore.. :icon_wink:
(raising R4 is equivalent to lowering R3 - although R3 isn't the only resistor in gain branch..)
Muttlyboy
