Building Guyatone PS-24 distortion : Diode question.
Started by eh la bas ma, April 26, 2023, 01:31:59 PM
QuoteThose MKT (82nF and 5nF) caps aren't much convenient, are they..?? :icon_wink:
(I bet their voltage rating is higher than 63V)
If you have 100nF's maybe easier to change the resistor from 100k to 82k.
When I see 5nF, someone has either converter (the text/value) 4n7 to 5n for polys or the original pedal used a 5n ceramic.
eh la bas ma
#21
I changed the big 82n for a smaller one.
Could also has been a tiny strand of wire coming out of the board and creating shorts with the next wire. I fixed two suspicious wiring pads.
Here is the build report, with audio samples and some observations on the 5-bands graphic EQ :
https://www.diystompboxes.com/smfforum/index.php?topic=36392.msg1265905#msg1265905
"One Cannot derogate, by particular conventions, from the Laws which relate to public Order and good Morals." Article 6 of the Civil Code.
"We must not confuse what we are and what society has made of us." Theodor W. Adorno.
