omit the transformer?
Started by Itchy Scratcherson, May 01, 2023, 02:35:12 PM
Itchy Scratcherson
Hi! Can someone help enlighten me and also please recommend a workaround? PCB is defx Shard & out-of-stock is the required Xicon 42TM022 transformer. You can locate the transformer in the busy schematic just to the left of the text/Title. Attached PDF specs for the Xicon 42TM series has what appears to be a very close alternative (highlighted), but that's also AWOL/ backordered.
(1.) Even though the xformer's primary is only used for getting the audio into the xformer, do I assume correctly that, in this circuit, the primary input impedance remains as important as it's secondary impedance?
(2.) If it's job is to simulate the loading of a pickup, how can I do this *without* that component?
(3.) Last, re: the possibility of omitting the transformer, the linked thread below states transformers only work with AC input.
(https://www.diystompboxes.com/smfforum/index.php?topic=73768.msg598559#msg598559:~:text=24%3A39%20AM%20%C2%BB-,Quote,-Check%20out%20some)
Is the Shard circuit working on AC up until the transformer?
Thanks for your help!
I mentioned I know just enough to be dangerous, right?
antonis
Transformer + diodes work for signal octave up.. :icon_wink:
There are many substitutions for that..
idy
The transformer is essential for the octave part of the circuit.
Yes, audio is a type of "AC" in that it swings up and down. So audio signals can be transmitted (induced) between windings of a transformer, but DC would only produce one little "jolt" when it turns on. Or off. The rising and falling of a magnetic field.
theehman
Hey, Itchy, I have a spare TM022 I can send you if want to cover the postage.
Ron Neely II
fx schematics and repairs
> out-of-stock is the required Xicon 42TM022 transformer. ....that's also AWOL/
The DEFX drawing has an error. If you ground two taps on one winding, it is a short.
In the 1970s, the transformer seemed to be simple and cheap. All you really need is out-of-phase signals, preferably strong. An added op-amp will do it. Someone here must know  a plan like that you can use.
Mouser used to have a lifetime supply of the little transformers. Also the datasheet. Similar impedance at different Max Power will work the same.
Itchy Scratcherson
QuoteYes, audio is a type of "AC" in that it swings up and down. So audio signals can be transmitted (induced) between windings of a transformer, but DC would only produce one little "jolt" when it turns on. Or off. The rising and falling of a magnetic field.
You just blew my fragile eggshell mind. Electrified audio is just magic.
