Adding blend control to Big Muff
Started by PBE6, April 03, 2014, 12:36:34 AM
akkar
Quote from: antonis on August 22, 2023, 05:48:59 AM
'Cause you quoted RG's http://www.geofex.com/Article_Folders/panner.pdf, where 1st page op-amps are powered from dual (symmetrical) supply..
(not clearly shown but guessed from non-inverting inputs bias..)
Sorry I'm still confused... I have a single +9V power supply, 9V goes to TL074 Vcc pin, ground goes to - pin, 4.5V (from voltage divider) goes to uninverting input.
Now what should I connect to the central tap of the potentiometer? Ground or 4.5V?
Quote from: akkar on August 22, 2023, 04:35:41 AM
Quote from: R.G. on April 03, 2014, 12:47:49 PM
Sorry if I resume this old thread... If I use for eg a TL074 for the inverters (creating a double power supply from the 9volts) should I connect the tap of the pot in the link to the 4.5V, instead of ground?
If you've got the standard Ground and +9V power with a 4.5V Vref then then pot wiper (and the other points marked with a little Ground triangle on the panner.pdf) goes to the 4.5V Vref.
As Antonis says, it's because the pdf shows things done with a full dual supply, whereas you're using a single supply with Vref.
antonis
What exactly does this mean..??
akkar
Quote from: antonis on August 22, 2023, 06:01:41 AM
9V -> voltage divider -> 4.5V
akkar
Quote from: ElectricDruid on August 22, 2023, 05:56:16 AM
Thanks.
I wonder if it's better to take it use the volume pot of the Big Muff as an overhaul level pot (taking the distorted signal input to the blend before the pot) or not as a control for the distorted channel only (taking the distorted signal input to the blend after the pot)
antonis
#25
Quote from: akkar on August 22, 2023, 05:55:37 AM
As long as:
1. non-inverting inputs are biased at 4.5V from respective voltage divider, and
2. +4.5V divider respective point is decoupled (via a cap to GND)
you're free to connect pot's wiper either to GND or +4.5V point.. :icon_wink:
(a decoupled bias point is considered AC ground..)
antonis
Quote from: akkar on August 22, 2023, 06:05:53 AM
:icon_biggrin: :icon_biggrin: :icon_biggrin:
(you probably wanted to mean "half"..)
