A good Noise Gate suggestion
Started by Baran Ismen, December 06, 2023, 03:33:41 AM
Baran Ismen
Just want to start with a noise gate project for myself and a friend (my first official order, yay!)
I seek nothing fancy, something without a send-return function (not needed), just to cut the hi-gain feedback & noise when not played (low-tuned, heavy-metal guitarist here) attack & decay are optional, I can set & forget them internally via Trimpot's even.
I was checking the MXR Noise Gate due to its simplicity, but there are disputes everywhere about the accuracy of the layouts & schematics provided on the Tonepad & effectslayouts blog. Some say it's working, whereas some fail to do so and suggest lots of changes. Also, the comments & build reports on both pages are quite old, so I'm unsure about their up-to-dateness, so I'm quite baffled right now about which one to follow.
ISP Decimator is a no-go due to unobtainable THAT ic, btw.
Any help will be most appreciated.
FiveseveN
Quote from: Baran Ismen on December 06, 2023, 03:33:41 AMnothing fancy, something without a send-return function
If the goal is to actually use it effectively and not just to exercise your building skills I urge you to reconsider. There is no good noise gate without a sidechain: you're stuck with either hiss (if you use it before distortion) or touchy threshold and abrupt decay (if you use it after).
I'm all for DIY but I just went for the Behringer NS-2 clone (modded for quicker decay) when I found myself needing a gate.
The SSM2166 and 67 both include excellent downward expansion, in addition to great compression, and are about as simple a build as making a grilled cheese sandwich.  You do not need to use the compression, but it's there if you want.
stallik
I don't know if this one is a 'good' noisegate but it's one have had on my board since I built it ages ago. I don't actually need a gate but really like the 'slow gears' effect it can give
https://www.diystompboxes.com/smfforum/index.php?topic=110395.msg1012330#msg1012330
Baran Ismen
Please don't focus on the term "good" that much, I just mean "something working as it should be" by that.
Quote from: Baran Ismen on December 06, 2023, 03:33:41 AMI was checking the MXR Noise Gate due to its simplicity, but there are disputes everywhere about the accuracy of the layouts & schematics provided on the Tonepad & effectslayouts blog. Some say it's working, whereas some fail to do so and suggest lots of changes. Also, the comments & build reports on both pages are quite old, so I'm unsure about their up-to-dateness, so I'm quite baffled right now about which one to follow
Correct Schematic:
https://www.diystompboxes.com/smfforum/index.php?topic=122689.0
Possible headaches:
https://www.diystompboxes.com/smfforum/index.php?topic=122682.0
A hold control can help tail-end fizz.  Some noise gates have a bit of a hold effed without having a control.   While good noise gates can be made with JFETs the VCA types are easier to get working but then you need a good VCA.
https://recordmixandmaster.com/2010-02-what-is-a-noise-gate
Baran Ismen
Quote from: Rob Strand on December 07, 2023, 01:28:59 AM
Correct Schematic:
Possible headaches:
For some reason I can't seem to see the pictures loaded on the image upload provider of this web-site, its probably blocked on Turkey  :icon_frown:
