Volume Boost/Output Buffer Options
Started by BennyBoy, December 12, 2023, 12:01:13 PM
BennyBoy
Hey folks,
I am currently working on improving an overdrive design and wanted to pick your brains! After getting some feedback on my drive, people wanted more output volume.
Because of that, I tried adding a clean boost op-amp stage after my tone control. Because I am already using a TL072 for the input buffer and the clipping stage, I figured I would use another TL072 here. This led me to wonder, why not swap the transistor output buffer I have for an op-amp buffer to use the other side of the 72. Any thoughts on potential drawbacks on this compared to the output section I have? Any suggested changes to my added boost stage? Thanks! (Also, please ignore the sloppy schematic drawing and weird resistors in place of pots, I just made this quick on LTSpice to test)
There he took up again his great Ring in Barad-dur, and dwelt there, dark and silent, until he wrought himself a new guise, an image of malice and hatred made visible; and the Eye of Sauron the Terrible few could endure.
Clint Eastwood
I wonder if you can't do without the input buffer. You can connect you guitar directly to the clipping amplifier. Or does the buffer stay in circuit when you switch off the overdrive? if not, you could use that op amp channel to make a fixed gain booster/output buffer. This way you can have all you want with just one TL72.
GibsonGM
Yes, per R.G. Keen's "son of screamer" at the bottom of this page:
http://www.geofex.com/article_folders/tstech/tsxfram.htm
Removing the input buffer would free up that '72 section.
Another +1 for that idea.
That first op-amp buffer is doing nothing, basically. You can get the same input impedance direct into the clipping stage. Just take everything that joins to U1 +ve input, and join it to U2 +ve input instead. U1 and the rest in-between can go.
That gives you a second op-amp to use instead of the output buffer, without needing to add a second TL072. And if you need a bit of gain on that output op-amp to get things back to unity or a bit more after the tone control, then why not?
On another note:
What's going on with that tone control? It looks like a Big Muff style thing, except the top end is just a divider with no cap at all. The bottom is ok - a lowpass.
antonis
Can't either get what's going with R19/R20..
(unless it's a Volume pot..)
P.S.
I DO know it's a drawing error but I still don't like to see U4 in such a #@* :icon_mrgreen:  :o  :icon_evil: wiring state.. :icon_wink:
Quote from: antonis on December 12, 2023, 03:50:25 PMCan't either get what's going with R19/R20..
Yeah, it's a "budget LTSpice Pot". R14/R15 is another for Tone. We've all done it. We mostly don't show it off though ;)
antonis
Quote from: ElectricDruid on December 12, 2023, 07:13:29 PMYeah, it's a "budget LTSpice Pot". R14/R15 is another for Tone. We've all done it. We mostly don't show it off though ;)
Should it be a lot of trouble if you inform us about it..??
or else, we are free to consider R11/R12 a 40k 10% pot set at 50% rotation..
BennyBoy
Quote from: ElectricDruid on December 12, 2023, 03:29:12 PMOn another note:
Thanks for the advice :D
The tone control is strange, but I wanted to keep it original to the circuit this is drawn from (the Yamaha OD-10MII). This is the original tone control from that pedal.
BennyBoy
Quote from: antonis on December 12, 2023, 03:50:25 PMP.S.
Just noticed that, sorry  :icon_cry: I redrew it just to take the screenshot and did it really quick lol.
BennyBoy
Quote from: antonis on December 13, 2023, 05:19:08 AM
R11 and R12 are actually part of the wonky tone control from the original pedal. The dividers at R14 and R15 and R19 and R20 are the only pot simulations (for gain I just maxed it out for testing purposes, 100k at R9). Here's my actual schematic from Eagle so you can see what's going on.
BennyBoy
Sorry all, didn't mean to start a controversy with my horrible LTSpice schematics!  :icon_lol:
antonis
Quote from: BennyBoy on December 13, 2023, 11:00:59 AMThis is the original tone control from that pedal.
Similar to Watson's EFY-6 Fuzz Tone control.. :icon_wink:
(a bit simplified..)
antonis
Quote from: BennyBoy on December 13, 2023, 11:09:42 AMSorry all, didn't mean to start a controversy with my horrible LTSpice schematics!  :icon_lol:
There can't be any serious controversy without duck_arse involvement..
(ElectricDruid is too noble for hassling..) :icon_wink:
