Power supply query
Started by Yazoo, December 02, 2023, 11:38:56 AM
Yazoo
There are schematics available online for the Roland JC-20 which have not been completely confirmed. I am looking at the power supply section, specifically the supply (Vdd) going to the MN3207 and MN3102 which has to be around 9V but definitely not above 10 volts. It uses a capacitance multiplier to filter noise out and is preceded by a Zener diode. The value of the Zener is unknown but I guessed at 9.1V. I can't understand how Vdd, the supply to the MN3207/MN3012, is regulated to around 9V as the schematic stands in the first attached picture.
I have amended the schematic, shown in the second picture, so that the transistor collector is connected at the mid-point of the resistor R44 and the Zener diode. Would this guarantee that Vdd would then be correct, i.e. 9.1 V for the MN3207/MN3012?
Amended version:
antonis
Basically, Vdd is Zener voltage minus Q3 VBE (minous a little voltage drop across R45..)
In amended version, VCE is restricted to 9.1 minus VBE..
(less power dissipation for Q3 but too much power dissipation inconvenience for R44..) :icon_wink:
P.S.
Both configurations DON'T guarantee 9.1V..!! :icon_wink:
(amended version Vdd is strongly dependent on Q3 hFE..) :icon_wink:
Quote from: Yazoo on December 02, 2023, 11:38:56 AMIt uses a capacitance multiplier to filter noise out and is preceded by a Zener diode.
The transistor also "multiplies" the Zener. The voltage on the Collector hardly matters; the Emitter will "follow" the Base which is fed no-more-than 9.1V.
The original looks right/workable.
Your "correction" mostly ignores the usefulness of the transistor and will sag badly on load much more than a BBD chip.
See also the second paragraph here. (The 3rd pp wanders away from factors we need in simple power supplies.)
Yazoo
Thanks for the information. I have built this and tested it with a 12V bipolar supply. The real thing will be around 15V. I wanted to check voltages before I put in the BBD so I left the MN3102 socket empty and put a led with resistor in the GND and V+ socket pins of the MN3207. I measured about 10.3 volts, too high for the BBD.
I want to regulate Vdd to a definite 9 volts without adding additional noise. Any advice would be very welcome.
antonis
7809 (1A) or 78L09 (100mA) regulator..
Quote from: Yazoo on December 02, 2023, 11:38:56 AMI have amended the schematic, shown in the second picture, so that the transistor collector is connected at the mid-point of the resistor R44 and the Zener diode. Would this guarantee that Vdd would then be correct, i.e. 9.1 V for the MN3207/MN3012?
Interesting, in another thread I just noticed the 15V and 27V rails look whacky as well.
Either version of those circuits would work.  None are conventional connections really.    The original will produce a slightly higher output voltage.
As suggested in the other thread,  look at some other versions of JC schematics.
Yazoo
I went ahead and added a 78l09 to get the correct voltage for the BBD. I was reluctant to do this because I did not want to add any additional noise. I'm in the process of boxing it up now. I managed to fry the two TDA2030s using a 15-0-15v transformer. I am now using a 10-0-10 transformer and it is working, maybe a loss in volume but for what I want, not a problem.
The puzzle is how did the BBD, MN3207, work in the original circuit without getting fried.
Absolute max Vsupply from the MN3207 datasheet is 11V, so 10V won't kill it. 10V is the recommended maximum working supply voltage.
