Why isn't my clipping stage working?
Started by drainyoo, December 10, 2023, 02:40:04 PM
antonis
I'd proceed with a DPDT switch for either "soft" or "hard" clipping.. :icon_wink:
Steben
Shouldn't there be a DC blocking cap in series with the feedback diodes from collector to base?
antonis
Quote from: Steben on December 11, 2023, 12:38:02 PMShouldn't there be a DC blocking cap in series with the feedback diodes from collector to base?
There should be more than that cap (it's Buzz-Fuss-alike..) but if OP likes it, let it be.. :icon_wink:
drainyoo
Quote from: antonis on December 11, 2023, 01:59:52 PM
Never heard of the Buzz-Fuss. Will check that out.
Why should there be a cap and more in the feedback loop? I'm not trying to go for a standard overdrive/distortion. Trying to come up with a different sound that is a little messed up.
antonis
#24
Quote from: drainyoo on December 11, 2023, 02:44:05 PMWhy should there be a cap and more in the feedback loop?
To "isolate" DC feedback (bias) from AC one..
In your ciruit, diodes overcome (shunt) 100k feedback resistor..
(you can see that in op-amp configurations but doesn't affect bias there..)
This results into 2 X Diode forward voltage drop(*) + VBE on Emitter
(100k resistor is practically redundant and stage gain is unpredictably variable(*)..)
(*) much lower that nominal due to very low forward current..
Also, for stage gain set by 100k/2k2 ratio, "open loop" gain (feedback resistor disconnected) should be the maximun availiable..
(Emitter resistor AC bypassed via a 22 - 47 μF capacitor..)
I do know I confuse you but the above need analysis beyond the scope of present thread.. :icon_wink:
P.S.
As I said before, if you like it, ignore the above recommendations and go for it..!! :icon_wink:
drainyoo
Quote from: antonis on December 11, 2023, 03:41:47 PM
P.S.
Yeah, took your advice and I removed that second gain stage, and just put a switch after the 100k resistor to remove it from the circuit. Once removed it turns into high distortion and it sounds great to me. Thanks for the suggestion! Still don't get why that second gain stage didn't work, though.
There is one other issue. When the Gain pot on the transistor emitter is turned all the way down, the signal level gets really low. I assume this is kinda normal since it is a gain pot, but is there a solution to reducing how much the level drops? I changed the pot to a B50k, and that helped a little.
antonis
Quote from: drainyoo on December 12, 2023, 10:56:29 AMWhen the Gain pot on the transistor emitter is turned all the way down, the signal level gets really low.
Of course, 'cause gain is set by RCollector / REmitter
Quote from: drainyoo on December 12, 2023, 10:56:29 AMis there a solution to reducing how much the level drops?
For a 20k Collector resistor value, Emitter gain pot value shouldn't be higher than 5k say (better 1k or so..)
(for a normal guitar signal amplitude..)
And don't forget to make 47nF cap much bigger, unless you wish for high gain at high frequencies..
(kind of Treble booster..)
drainyoo
Thank you for all your help. I will try these out.
Vivek
Should there be a DC blocking capacitor near the diodes near the base and collector ?
antonis
Quote from: Vivek on December 12, 2023, 01:30:08 PMShould there be a DC blocking capacitor near the diodes near the base and collector ?
 :icon_lol:  :icon_lol:
antonis
Quote from: drainyoo on December 12, 2023, 01:00:24 PMI will try these out.
Based on your own design, I'd try the following configuration.. :icon_wink:
drainyoo
Quote from: antonis on December 12, 2023, 01:52:59 PM
But why? Explain like I'm a 5 year old. I guess what will help me understand is, what bad comes out of not having a cap there? Is it just the proper way of doing things?
I'll tell ya, it sounds great to me without a cap there.
antonis
drainyoo
#33
Quote from: antonis on December 12, 2023, 02:42:11 PM
Quote from: drainyoo on December 12, 2023, 02:30:13 PMBut why?
I presume you didn't understand post #24 above.. :icon_wink:
Go to "Biasing with Collector Feedback resistor" and place a diode across RB
I didn't. It was beyond my knowledge, but I appreciate you explaining. This link looks helpful, I'll read through it.
For reference, I'm biasing the transistor to 2.5v because I like the busted up sound it makes. It's what I'm going for. It reminds me of what a Super Reverb sounds when you overdrive it with a lot of bass. Love that sound.
antonis
Quote from: drainyoo on December 12, 2023, 03:16:40 PMI'm biasing the transistor to 2.5v
With what Collector & Emitter resistors values..??
drainyoo
Quote from: antonis on December 12, 2023, 03:39:06 PM
A 5k gain pot, and 10k & 6.8k at the collector. The resistor with the diodes is still 100k.
antonis
#36
Quote from: drainyoo on December 12, 2023, 05:30:34 PMA 5k gain pot, and 10k & 6.8k at the collector. The resistor with the diodes is still 100k.
If diodes are C-B directly coupled (no series capacitor), you didn't bias it..
It is self-biased, in the mean of VCE is 2 X Diode forward voltage drop + 1 X VBE..
In case of diode series DC blocking cap existence, 100k feedback resistor value should be raised..
(for more voltage drop across itself, hence lower Emitter voltage and lower Collector current, resulting in lower voltage drop across Collector resistor - Collector more close to (+9V + VEmitter) / 2 ..)
P.S.
2.5V Collector bias calls for 1.75V negative headroom, which should be OK for Si diodes but should result into asymmetrical clipping for diodes of higher forward voltage drop..
(e.g for LEDs ..)
BennyBoy
Quote from: antonis on December 11, 2023, 10:51:26 AMI'd proceed with a DPDT switch for either "soft" or "hard" clipping.. :icon_wink:
+1 this.
Easy and interesting solution!
There he took up again his great Ring in Barad-dur, and dwelt there, dark and silent, until he wrought himself a new guise, an image of malice and hatred made visible; and the Eye of Sauron the Terrible few could endure.
