AION Lumitron (Mutron-III) - Switch positions unclear
Started by Quiddel, December 15, 2023, 08:30:02 AM
Quiddel
Hello,
I am currently designing the decal for the Lumitron project by AION, which is a clone of the MUTRON III envelope filter (see image below). I won't be able to solder the PCB for quite some time, but would love to prepare the enclosure already.
So I am wondering if anyone could help me with the correct labeling for the positions of the Drive, Filter and Range switches. Is it correct like this:
Drive: DOWN - UP
Filter: LP - BP - HP
Range: LO - MID - HI
And if I may, as a general suggestion to @aion, would it generally be possible to include the respective switch positions in your build documentations? It would be great to be able to fully prepare the enclosure before soldering the project. For the projects where there is the full kit, I can check your enclosure design. But for all the other great projects it's not easy to find out.
Thanks a lot,
Matthias
aion
Range is actually Low - Hi - Med since the Hi position needs the center-off. The other two are correct though. I'll make a note to add these to the drill template, I've been doing it for bigger projects like the Lovetones but didn't think to for this one.
Quiddel
Thanks a lot! Let me use the occasion to say that I really love your projects and documentations a lot. I appreciate the detailled background info about the circuits!
tootsMcgee
Quote from: Quiddel on December 18, 2023, 06:14:58 AMThanks a lot! Let me use the occasion to say that I really love your projects and documentations a lot. I appreciate the detailled background info about the circuits!
Seconding this, and thank you for adding the info to the docs Aion! I was confused on this pedal as well but haven't had time to play too much with it. It sounds great.
