BSIAB II mods with sound demo
Started by Xavier, January 05, 2024, 02:08:32 PM
Xavier
Hi all !!;
It's been an eternity since I last posted here, the place where I learned all things DIY...........
I've had a bit of a nostalgic throwback, revisiting some of the old boards I had in the junk bin.
I just pulled the BSIAB, added the pots , boxed it again and voilá !! It's alive again.
It's basically stock, with the only changes of C13 (500pF) and C14 (1nF), although I may still increase the values a bit, to both 1,5nF....... these are not improvements, but adaptations to the amp I'm using.
I've also tried to add a "C0" t cut some of the bass into the circuit and make it tighter. I tried 4n7 and 6n8. They thightened up the bottom end, but at the expense of losing oomph, so for now I have left the circuit stock.
I am an 80's metalhead through and through and I haven't heard too many good sounding demos, so here it is , just too make clear that this thing reigns at those type of sounds:
- Double tracked (first clean, then pedal on)
- Straight into DAW (with a software cab emulator)
- Slight reverb
BSIAB sound demo
GibsonGM
I hope you were wearing spandex and had your hair puffed up good for this.
But it sounded great, like a wall of Marshalls, and NOT the empty cab kind like Kiss use.
Xavier
You guys helped me a lot when I started, answering many questions and inspiring me to, nice hearing back from you again, and I hope you are all well !
You guys are legends !
