My Most Aesthetic Layout Yet - 6 Band EQ w/ footswitchable boost
Started by drdn0, November 19, 2023, 06:09:56 PM
drdn0
...only I wish I didn't scratch the switching PCB while trying to change CLR's and then attempt a fix with Sharpie  :D
More satisfaction from soldering this bad boy than just about anything else I've done.
Phend
  • SUPPORTER+
Do you know what you're doing?
Quote from: Phend on November 20, 2023, 10:08:57 AMVery nice, get a clear bottom cover for it !
..and do the link between the two boards in nice rainbow ribbon cable!
drdn0
Unfortunately, the cover connects to the switching PCB through a pogo pin for shielding, so it's gotta be bare aluminium. Would be cool though!
Quote from: ElectricDruid on November 20, 2023, 03:43:01 PM..and do the link between the two boards in nice rainbow ribbon cable!
I'll have to see if I can get FFC's in colours - that would look pretty sick.
Ben N
How do you manage with the jacks on the sloped sides of the enclosure? Do you solder them in slightly off horizontal, or do you just not worry about it?
