zonk against the machine
Started by karsten_h, February 09, 2024, 01:43:00 PM
karsten_h
... anyone ever checked this circuit? experience? suggestions? opinions?
https://www.thetonegod.com/diy/zatm
... just standing on the shoulders of the diy stompbox scene out there.
JustinFun
No, but I'm going to now!
Haven't seen this and have been fiddling around on a silicon mki tonebender for a while now with no success, so this. looks like an excellent starting point
antonis
As far as Q3 is Si BJT, it can't work without DC bias.. :icon_wink:
(Ge might rely on leakage current, althougt unpredictable..)
Also, R7 better be connected on Q2 Collector (feedback bias) 'cause, as it is, Q2 out is strongly depended on partiqular device hFE..
antonis
#3
A more BJT junkbox friendly circuit.. :icon_wink:
edit: TONE pot, C3 & R7 values set for more convenient adjustments..
Quote from: antonis on February 09, 2024, 03:47:16 PMQ3 is Si BJT, it can't work without DC bias..
It will, while the signal into Q3 is large enough (half-volt or more).
I assumed that was the job of Q1 Q2.
And that the "gate" on decay was part of "the sound". Self-muting after 3-transistor distortion may be a relief.
antonis
#5
Quote from: PRR on February 10, 2024, 04:46:05 PMIt will, while the signal into Q3 is large enough (half-volt or more).
It works only for a couple of seconds..
(while capacitors are discharged..)
After that:
150mV input, LEVEL at max..
JustinFun
Yeah, it doesn't work at all as drawn (the original schem, haven't tried atonis' version yet).
Surprised to read on the blog post "I found the response of the Si circuit quite similar to the Ge version so I think I succeed in keeping the spirit of the circuit intact."
antonis
Quote from: JustinFun on February 13, 2024, 11:49:51 AMhaven't tried atonis' version yet...
You'll get something like this:
karsten_h
Quote from: antonis on February 13, 2024, 03:20:46 PM
amazing! how did you simulate these graphs?
antonis
karsten_h
thx for investing your time here will give it a try pretty soon...
