ADA Flanger revisions values Question
Started by RaceDriver205, March 23, 2007, 04:31:44 AM
RaceDriver205
Regarding mooses parts list, which of the columns of parts values should I use.
Should I just use rev4, will this be satisfactory? Why have the parts been changed?
Thanks.
John Lyons
I have not gone through all the posts, revisions and modifications but I'd like to get started populating my board. I'm still in the dark as to which version to build. Which would be a good base version to start with? Maybe a quick rundown of the versions would be in order.
John
Basic Audio Pedals
www.basicaudio.net/
joelap
+1, that 40+ page thread is overwhelming!  I've got a board sitting here that wants to see some action.  I know moosapotamus has a bunch of files on his site for a parts list and what have you over there.
- witty sig -
stumper1
DericĀ®
RaceDriver205
Bump. We really need an answer to this.
oldschoolanalog
I looked thru the "megathread" and came up w/this. I believe the builders in question used Charlies' component values (refer to schem.), w/the exceptions listed. Check out...
Page 20, reply #384. Page 25, reply #493. Page 26, reply #518. Hope this helps a bit.
Now the good news. I finally got a good meter w/a frequency counter (tax return time 8)). I finally got the opportunity to see how close my "by ear" calibration was. It clocks from 16.8 khz to ~740 khz. Actual clock measurments,taken from the clock outputs, not that TP test point. Not bad for "by ear". So, YES, it should not be a problem to calibrate. Hope this reduces the "fear factor" involved with process. I wish all building this total success! You will LOVE this one!
Rock Steady,
osa
Mystery lounge. No tables, chairs or waiters here. In fact, we're all quite alone.
moosapotamus
I've got a board all stuffed with the values shown in my schematic.
As soon as I have time to wire it up and test it out I'll report back. 8)
~ Charlie
moosapotamus.net
half_smith
Is there a current BOM for ADA Flanger available?
