Geofex Lera not working properly
Started by freshmex18, August 16, 2024, 08:39:08 PM
freshmex18
I take that back.  There is an audible ticking when in the Up position.  Anything that can be done about that?
There is also oscillation even with a 10uF at the output of the 78L05
freshmex18
Looks like the oscillation is from a bad power supply.  Plugging it into my pedalboard brick seems to solve that problem.
Buffer before the pedal made the ticking stop.  Will build a buffer to stick inside the pedal and see what that does for the final build.
