Better options for internal wiring
Started by marcelomd, March 07, 2025, 12:31:36 PM
stallik
Made these up so I can use 1.27mm pitch computer ribbon cable
Neat idea, Kevin.  But rather you than me soldering up that ribbon cable!
I'd go with IDC sockets and box headers:
  (I think you can get six-way versions.)
Fancy Lime
Quote from: PRR on March 16, 2025, 06:34:24 PM
Quote from: marcelomd on March 07, 2025, 12:31:36 PMjust look at the wiring. Is there a better way of doing it?
Wrong fluid, and won't work in our climate, but I really like this. Mistakes easy to see, leaks obvious, repairs out in the open.
https://www.youtube.com/shorts/YTXqQy-X17g?feature=share
Yeah ok, this would normally be inside a wall but other than that: How else would you do it? Seriously, I have never seen any pipes installed any differently than that except in the most make-shifty of applications.
marcelomd
Managed to source the male counterpart to the machined sockets.
Also bought a few different JST connector sets with different pitches (pre assembled and not).
Will take measurements when everything arrives and spin a new version of these preamps to use them. Luckily this will be the last version of this particular circuit.
Question: How much crosstalk should I expect with flat cables? None, I think, but maybe someone has more experience.
