subing reistors in ts808 clone Q?
Started by nightingale, December 29, 2003, 06:49:44 PM
nightingale
hello~
i am populating another ts808 board... the schemmo calls for 510k resistors...
the closest i have on hand are 470k... is this going to be a problem?
i would rather no put 2 in a series to get a closer value... because my board is pretty cramped...
hmmmm, :?
be well,
ryanS
www.moccasinmusic.com
Craig V
I'd say 470k is close enough.  The 510k's are all power rail resistors, so the circuit will have slightly more voltage.
Samuel
If you don't mind little resistor rainbows on your board you can always series a 47K in there...
