Diff btw tonepad amz mosfet booster/GGG's amz mosfet booster
Started by jimbob, January 16, 2004, 12:47:40 AM
jimbob
Im wondering why/if there is a diff and if so which is a better circuit. The Tonepad lists a few xtra parts..2n5485, 1n914, and a 22k.
"I think somebody should come up with a way to breed a very large shrimp. That way, you could ride him, then after you camped at night, you could eat him. How about it, science?"
bwanasonic
The main difference is the tonepad layout includes circuitry for the millenium bypass. If you plan on using the millenium, then that's a good thing, otherwise :? GGG uses an existing board layout of JD's and put's it to use for this circuit. Neither is *better*. I built mine on pad-per-hole perf using Jack Orman's schematic and my own layout with a 3PDT for switching.
Kerry M
jimbob
I love it and use it everyday !!!
 Mosfet Boost ROcks...~No Dirt in it.
 Compare to LPB...then run a MB into one...
jimbob
I built the Lpb2 and for what it is-esp low part count and build ease-great..But, i thought there was some distortion leaking into it--w the sound. I thought there had to be something cleaner.
