Need a second (or third) opinion... (wiring question)
Started by sstim8or, January 19, 2004, 04:33:26 PM
sstim8or
I've got a project in the drawing-board stages. It's basically two boosters in series, based on the EH LPB and Screaming Bird circuit. I've added switches so the capacitor values can be switched around. Anyway, I'm trying to sort out the power wiring. If any of you gents have a moment, have a look at this and tell me if everything looks right. Thanks!
Mike Burgundy
should work ok, although I wouldn't connect the output ground (it's grounded through the box if you use metal boxes and jacks) and I'd make the input ground the central ground point: for power, and BOTH boards. I'm completely missing what's going on with the signal wiring however: do you have two boards with two boosters each? I'd expect wiring like it's two pedals with interconnecting jacks taken out, but this looks a bit confusing to me.
hih
