BYOC Reverb... Working but no Bypass signal???
Started by cdc3j, April 12, 2011, 04:52:19 AM
cdc3j
Just finished the pedal and it works great but when it's switched off there's no signal. Seems weird to me. All the connections are right according to their layout. Help?
anchovie
  Where's it stoppin' off at ?
   Try DMMin through the traces/follow the circuit path through to stop point or same with audio probe.
Fender3D
If you try to figure out what are the 2 switch's different directions, one working and the other one not working, I bet you'll achieve your goal...
cdc3j
I replaced the switch. Works fine now. Must have been a faulty switch. Thanks
Paul Marossy
Quote from: cdc3j on April 12, 2011, 05:18:51 PM
I've run across those before. One in my last batch failed the very first time that I went to use it.  :icon_mad:
