Powering LEDs from Negative Voltage
Started by yano, February 27, 2004, 02:46:21 AM
yano
I've got a MAX1044 generating negative voltage off of a +9V line and I'd like to have a power indicator...that also indicates the 1044 is working. The easiest way I can think of to do that would to just power the LED off of the negative voltage supply. Is this possible?
As long as you're measuring 9v difference.
 You may have to turn the LED around for it to light.
 Use a 4k7 or better resistor on the LED, so it doesn't burn out.
 I'm assuming you're planning a 3PDT bypass w/indicator setup...the only thing I think of is the small PS needs of the LED that probably won't be a bother.
yano
Thanks, I'll try this out with my breadboard...I was worried that I might fry my led.
Actually, the light is a power indicator for a mixer i'm working on....No batteries involved, its strictly jack powered, so I don't really care how much power I draw.
smoguzbenjamin
You should care. If you over-do the current draw you'll fry your PS. Make sure that your PS will be able to supply enough current, preferably with a 30% safety margin!
Samuel
an LED can't pull much more than 20mA can it? Or am I misunderstanding?
smoguzbenjamin
You're right, I also use 20mA for a max LED rating. But 20mA is quite a lot, considering that an effect circuit will probably draw only a quarter of that ;)
