How to add LED?
Started by koa-dogg, March 21, 2004, 08:56:52 PM
koa-dogg
How do I go about adding an LED to my Home Build Pedals? Do I need to use one of the Melenium Circuits?
Thanks,
Scott
niftydog
not if you've got a spare pole on your switch... otherwise you may need the millenium bypass.
there's heaps of info about this already here.  Check the FAQ
niftydog
Shrimp down the pants!!!
koa-dogg
Thanks! I forgot to look there!
Scott
koa-dogg
Are there any diagrams for hooking up a 3PDT switch for True Bypass and LED? Also, How do I choose an LED and Resistor to work it properly?
niftydog
Well... nothing says "true bypass" like a hard wired switch to select between clean and effected signals.
To add an LED, use a spare pole of your switch to connect the LED and resistor to the supply when the effect is on.
LED's require different currents depending on the LED.  I generally run most LEDs at or around 10mA.
So, assuming you're using 9VDC supply, you get roughly 10mA by using a 900ohm resistor.  Try an 820 ohm or a 1kohm.  Note that the switch shown is SPST.  To use a DP simply leave the unused pin unconnected.
Use ohms law to find this;  volts = current * resistance.  rearrange as required.
           VCC
         \  o
          \    switch
            o
            V  LED
           | | 1kohm resistor
           GND
                 clean -o
                         \--o- output
                effect -o
niftydog
Greg M.
There are some diagrams listed "Offboard Wiring" at tonepad.com.  Five different ways to hook up switches, etc.--some with LEDs.
zener
Oh yeah!
aron
Quote from: koa-doggAre there any diagrams for hooking up a 3PDT switch for True Bypass and LED? Also, How do I choose an LED and Resistor to work it properly?
There is a forum created for beginners. It's called the "Beginner Project". In there you will find answers to a lot of questions that a beginner will ask including how a 3PDT switch works and how to hook a circuit up to a 3PDT for true bypass and LED.
In addition, there is a DIY FAQ, GEO FAQ, along with the FAQ Forum and finally a Search function on the top of the forum.
Happy searching!  :)
