double time
Started by axis, March 26, 2004, 07:14:32 AM
axis
Hey all,Are there any complications in housing two circiut boards in the same enclosure;ie a phaser  and  fuzz face together.Also, I understand that most fuzz faces like to be first in line in the effects chain from guitar to amp.So  what is the easiest way to have two fuzz effets in the rig without stealing the guitar signal from one of the effects.Thanks for  any info.
Build a better fuzz face and the world will beat a path to your door.
Only problem I've encountered is noise with a high gainer next to another amplification type cct
 I have an Obsidian Fuzz in box with LPB Booster, [wired one OR the other ....a cct on each side of the stompswitch] the Gain knob on the Obsidian being past 7 makes oscilation noisies come through the boost tone.
 {  } or something seems to 'mess' with my FF's when I tried it once or twice IIRC.
 I've gotten away with it N/P before.
 I not following your question about 2 Fuzzes in a rig...do you mean a seriesed chain?  Guitar> Fuzz>Second Fuzz> amp?
axis
Well,the problem is if  either one of my fuzz faces(octavia,fuzz face)aren't plugged directly to the guitar signal the effect completely drops out in intensity.
