Where does this connect?
Started by zener, March 28, 2004, 12:29:49 AM
zener
http://www.morleypedals.com/pwa-ii.pdf
There's the reference in the R32 from pin 5 that says (+ v/2). Where I will connect that?
Thanks for any help.
Zener
Oh yeah!
Travis
+V/2 is half of supply voltage, 4.5 volts in this pedal.  I don't see this included in the scchematic (of course, it is sideways)
Normally we use a voltage splitter: two 10k resistor in series, from +9 to ground.  The connection in the middle should be at 4.5 V
Joep
I looks like to be the connection between R3, R4 and C3.
Bye,
Joep
