Best way to clean perf boards?
Started by MattAnonymous, April 02, 2004, 07:05:05 PM
MattAnonymous
What's the best way to clean perf boards for reuse?  To remove old solder and components?
It's people like us who contribute to dead fx pedals selling on eBay for what they'd cost new!
B Tremblay
Here's what I do when I decide to scrap a perf build and want to salvage some of the components and board:
Using braided copper wick, I desolder the "keepers," which are usually sockets or caps that happened to have a decent length of lead remaining.
Next, I clip the leads of all the remaining components where the they enter the holes on the top.
I can then rip off the spiderwebs of solder and leads from the bottom with needle-nose pliers.  A number of the pads will pull off, but not too many if the original soldering was neat.  If you want all the pads to be intact, then a long session of tedious desoldering is in order.
Finally, I use some 220 grit sandpaper to lightly shine up the pads that survived the process.
B Tremblay
runoffgroove.com
aron
In general, pad-per-hole perboard is not re-usable. I have no idea about non-pad-per-hole.
For cleaning before soldering, heck, 3M scrub and water :-)
